810
Highlighted
Beginner
ASA5505 - IP FLOW TOP or IP Accounting
How does one find the top user or IP accounting with this ASA5505 v7.22 device?
With 1841 ISR:
sh ip accounting
sh ip flow top
Very lame if they don't have similar commands or capabilities on the ASA series.
1 REPLY 1
Highlighted
David,
The version that you are running is very old. The IP accounting Im not sure what it does, but the show IP flow, I am almost 99% sure that it has to do with Netflow, which was introduced on the ASA in version 8.2 and higher.
Just looked for the IP accounting and mostlikely, all that you are asking for is implemented on Netflow, here is more info:
https://supportforums.cisco.com/docs/DOC-6114
You can upgrade to 8.2.1 not having to do much of a change, now that you know that you are running an old version, please do not consider to (mind as well) upgrade to the latest version without reading what it first needs to be done. The upgrade to 8.2.1 should not be much of a change.
Mike Rojas
Mike
Content for Community-Ad
