ASA5506 Firepower with ASDM - Report Problem
crusier2015
Hi Friends,
I installed more than 3 ASA5506 with Firepower on my customers, and all of then occurs the same problem, always on Report show "Not Available" or "Unknown".
Someone get success to fix this problem???
Rishabh Seth
Level 7
Level 7
Is the logging enabled in access policy?
R.Seth
Yes logging is enable.
I would suggest you to contact TAC and troubleshoot the issue you are facing.
R Seth
But for you, never show "Not Available" or "Unknown" ?
