04-02-2015 06:35 AM - edited 03-11-2019 10:43 PM
I face some nat problem. i have ASA5512 iOS 9.3 its connect outside (ip: 37.10.1.2/29) for internet and inside (ip 10.78.61.1/24) for LAN and server.
I configure dynamic nat for internet its work. In LAN switch has 4 VLAN one server VLAN ip add 10.88.61.0/24.
Now i map a public ip 37.10.1.3 for server 10.88.61.10 from outside internet its work. But when i try to ping server public ip 37.10.1.3 from LAN its not ping but server local ip 10.88.61.10 ping from LAN.
How can solve the issue i need to ping public ip from LAN. ALL LAN VLAN are nat on ASA outside interface (ip: 37.10.1.2/29).
interface GigabitEthernet0/0
description #### Connect TO Internet ####
nameif outside
security-level 0
ip address 37.10.1.2 255.255.255.248
interface GigabitEthernet0/1
description #### Connect TO Core Switch ####
nameif inside
security-level 100
ip address 10.78.61.1 255.255.255.0
access-list outside-in extended permit ip any any
access-group outside-in in interface outside
access-group outside-in in interface inside
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj_Ser
host 10.88.61.10
object network obj_Ser_WAN
host 37.10.1.3
nat (inside,outside) source static obj_Ser obj_Ser_WAN
nat (inside,outside) dynamic 37.10.1.4
same-security-traffic permit intra-interface
Afzal
Solved! Go to Solution.
04-02-2015 06:51 AM
Try this NAT:-
nat (inside,inside) source static obj_Ser obj_Ser_WAN
Thanks and Regards,
Vibhor Amrodia
04-02-2015 06:51 AM
Try this NAT:-
Thanks and Regards,
Vibhor Amrodia
04-05-2015 01:56 AM
Its works now.
Afzal
04-05-2015 03:48 AM
Thanks ALL.
