ASA5515-X active/stand-by problems
Daniel Leonard
Hi Experts!
I've successfully setup two ASA5515-X (both with 5515-IPS) in active/standby mode. When the primary ASA's goes offline(failover testing) the standby ASA became active. So far so good.
When I test the following situation, 70% of the time I'm running into trouble.
1.     Reload/powerfail secondary ASA
2.     a few seconds later, reload/powerfail primary ASA
After doing this, the secondary ASA doesn't see an "active mate" and will become the “active” ASA. The primary ASA will also became in "active" state and sees the standby ASA in "failed state"!!
When I look in the secondary (now active) ASA I can see that the failover configuration is disabled!!
no failover
failover lan unit primary
failover lan interface failover GigabitEthernet0/5
failover key *****
failover link failover GigabitEthernet0/5
failover interface ip failover 1.0.0.5 255.255.255.252 standby 1.0.0.6
When I configure the secondary ASA (console ), with the following configuration. The secondary ASA gets back online in “Standby ready” state… problem solved ........
asa# conf t
asa(config)# failover
This is an undesirable and not stable failover situation! Both of the ASA's became active and causes ip conflicts.
Within a few weeks, I need to install this devices. Hopefully you can help me with this problem.
Device overview:
ASA5515-X software: 9.1(2)
ASDM: 7.1.3
ASA5515-IPS Software version:  7.2(1)E4
Please rate or mark answered for helpful posts.
5 Replies 5
Julio Carvajal
Hello Sr,
Certainly not expected at all,
So you reload the secondary box and when it comes up it sees itself as the active unit (even if the primary one is there acting as the active one) right ?
Can you share the
show failover history (with the relevant information after the standby unit comes back up)
Do you have logging enabled, anything interesting regarding the logs at the time of the problem ( level 1 messages )
show failover events
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Julio,
Thanks!
"So you reload the secondary box and when it comes up it sees itself as the active unit (even if the primary one is there acting as the active one) right ?"
No, on that moment both of the ASA's where booting. Like I said; I reload the secondary ASA first and a few seconds later I reload the primary ASA. Then the problem arises
When I reload the secondary ASA and the primary ASA stays active, then there is no problem at all.
thanks,
Niels
Okey, now it's a little more clear
You reboot it the ASA Secondary firewall first, so it will came up first but as soon as the other ASA booted it should detect it,
So again after both of the devices boot up can you share the commands requested before:
All of them will be need it to move forward. Also I will need the following command ( show startup-config)
If u do not want to publish your startup-config on this site u could send it privately to my cisco email address
Julio Carvajal
Hi Julio,
Thank you for taking time
I just reproduced the problem to get the needed log files. I will send the configuration by mail, hopefully you can help me further with it.
To reproduce this problem I reloaded the standby ASA first, a few seconds later I reloaded the active ASA.
primary (normal active) ASA:
MS-DC-ASA02# sh failover
Failover On
Failover unit Primary
Failover LAN Interface: failover GigabitEthernet0/5 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 2 of 114 maximum
Version: Ours 9.1(2), Mate 9.1(2)
Last Failover at: 19:40:20 CEDT Jun 2 2013
        This host: Primary - Active
                Active time: 1034 (sec)
                slot 0: ASA5515 hw/sw rev (1.0/9.1(2)) status (Up Sys)
                  Interface outside (xx.xx.xx.xx): Normal (Not-Monitored)
                  Interface mngt-lan (172.16.251.6): Normal (Not-Monitored)
                  Interface internet-lan (172.16.255.65): Normal (Waiting)
                  Interface dmz-lan (172.16.255.97): Normal (Waiting)
                  Interface management (192.168.241.6): Normal (Not-Monitored)
                slot 1: IPS5515 hw/sw rev (N/A/7.2(1)E4) status (Up/Up)
                  IPS, 7.2(1)E4, Up
        Other host: Secondary - Failed
                Active time: 0 (sec)
                slot 0: ASA5515 hw/sw rev (1.0/9.1(2)) status (Unknown/Unknown)
                  Interface outside (0.0.0.0): Unknown (Not-Monitored)
                  Interface mngt-lan (172.16.251.7): Unknown (Not-Monitored)
                  Interface internet-lan (172.16.255.66): Unknown (Waiting)
                  Interface dmz-lan (172.16.255.98): Unknown (Waiting)
                  Interface management (192.168.241.7): Unknown (Not-Monitored)
                slot 1: IPS5515 hw/sw rev (N/A/) status (Unknown/Unknown)
Stateful Failover Logical Update Statistics
        Link : failover GigabitEthernet0/5 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         0          0          0          0
        sys cmd         0          0          0          0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        0          0          0          0
        UDP conn        0          0          0          0
        ARP tbl         0          0          0          0
        Xlate_Timeout   0          0          0          0
        IPv6 ND tbl     0          0          0          0
        VPN IKEv1 SA    0          0          0          0
        VPN IKEv1 P2    0          0          0          0
        VPN IKEv2 SA    0          0          0          0
        VPN IKEv2 P2    0          0          0          0
        VPN CTCP upd    0          0          0          0
        VPN SDI upd     0          0          0          0
        VPN DHCP upd    0          0          0          0
        SIP Session     0          0          0          0
        Route Session   0          0          0          0
        User-Identity   0          0          0          0
        CTS SGTNAME     0          0          0          0
        CTS PAC         0          0          0          0
        TrustSec-SXP    0          0          0          0
        IPv6 Route      0          0          0          0
       Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       0       0
        Xmit Q:         0       0       0
MS-DC-ASA02# sh failover history
From State                 To State                   Reason
19:40:15 CEDT Jun 2 2013
Not Detected               Negotiation                No Error
Negotiation                Just Active                No Active unit found
Just Active                Active Drain               No Active unit found
Active Drain               Active Applying Config     No Active unit found
Active Applying Config     Active Config Applied      No Active unit found
Active Config Applied      Active                     No Active unit found
MS-DC-ASA02#
Secondary (normal standby) ASA:
Failover Off (pseudo-Standby)
Failover unit Secondary
Interface Policy 1
MS-DC-ASA02#
19:39:49 CEDT Jun 2 2013
Negotiation                Cold Standby               Detected an Active mate
19:40:22 CEDT Jun 2 2013
Cold Standby               Disabled                   HA state progression failed
MS-DC-ASA02#
Below the configuration I've made on the secondary (normal standby) ASA to let it work again.
MS-DC-ASA02(config)# failover
Beginning configuration replication from mate.
WARNING: Failover is enabled but standby IP address is not configured for this interface.
ERROR: Failed to start client services
End configuration replication from mate.
20:01:06 CEDT Jun 2 2013
Disabled                   Negotiation                Set by the config command
20:01:08 CEDT Jun 2 2013
20:01:09 CEDT Jun 2 2013
Cold Standby               Sync Config                Detected an Active mate
20:01:18 CEDT Jun 2 2013
Sync Config                Sync File System           Detected an Active mate
Sync File System           Bulk Sync                  Detected an Active mate
20:01:32 CEDT Jun 2 2013
Bulk Sync                  Standby Ready              Detected an Active mate
MS-DC-ASA02#
Niels
It looks like somehow after rebooting the Standby firewall it does not maintain the "failover" command,
I can't check the configuration on my cisco account email until tomorrow (dont have access from home) so I will analize it tomorrow but interesting case man,
Glad to help on this one
Julio Carvajal
