basic pix problem inbound & outbound traffic....
after1111
Level 3
Level 3
I have a problem with pinging. I can ping to workstations on the 192.168.100.x network but I cant ping the outbound interface (e0) onthe same network.
The second problem is I can ping from outside to inside, ive set acl and static route but didnt work.
I just want to pc1 to be able to get through pix to pc 2 and vice versa. Please give me a sample configuration.
here's the config:
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password xxx
passwd xxx
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl_out permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 192.168.100.1 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
no ip address intf2
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 192.168.100.150-192.168.100.200 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group acl_out in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
: end
harishtandon23
Level 3
Level 3
Hello!
If you are not able to ping the outside interface of the pix from inside host, but able to ping the outside host from the inside host. it is fine. As it is security feature designed in pix ASA. You can't ping the interface ip address of the pix from the host connected to the other interface.
Regarding the other issue, please try the following command:
global (outside) 1 interface
static (inside,outside)
wr mem
cl xlate
Where, is the free public ip address in the pool that can be used to map the pc1 on the inside.
Other configuraiton looks fine. If you have any questions, please feel free to contact me.
Thanks & Regards,
Harish Tandon
[email protected]
harishtandon23
Level 3
Level 3
Hello!
wr mem
cl xlate
Thanks & Regards,
Harish Tandon
[email protected]
thanks for time Harish.
All the best...
