12-21-2012 12:16 AM - edited 03-11-2019 05:39 PM
Dear forum,
For some reason there are some sites that I cannot access websites from inside interface.
One such example is lxer.com where I am receiving this message in the browser:
The connection has timed out
The server at www.lxer.com is taking too long to respond.
This has "suddenly" happened, and so I am wondering what others have done when such things has happened.
My outside has a dhcp-IP, and I have noticed that this address had changed, so I corrected this in my router settings.
ASA version is 5505
These are my settings:
: Saved
ASA Version 8.4(2)
hostname ciscoasa
domain-name example.no
enable password 123412321 encrypted
passwd 1231231 encrypted
names
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 12
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp
interface Vlan12
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 192.168.2.1 255.255.255.0
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns domain-lookup outside
dns domain-lookup DMZ
dns server-group DefaultDNS
name-server 193.75.75.75
name-server 192.168.1.11
name-server 192.168.1.12
name-server 193.75.75.193
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network inside-net
subnet 192.168.1.0 255.255.255.0
object network NETWORK_OBJ_10.10.10.0_28
subnet 10.10.10.0 255.255.255.240
object network NETWORK_OBJ_192.168.1.128_27
subnet 192.168.1.128 255.255.255.224
object network NETWORK_OBJ_192.168.1.0_24
object network NETWORK_OBJ_192.168.254.0_28
subnet 192.168.254.0 255.255.255.240
object network dmz-ftpserver
host 192.168.2.101
description FTP server Host Object
object network dmz-webserver
host 192.168.2.100
description Web Server Host Object
object network ftp-server
object service FTP
service tcp source eq ftp
object service WWW
service tcp source eq www
object network DMZ.net
subnet 192.168.2.0 255.255.255.0
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network NET-VPNPOOL
network-object 86.62.136.0 255.255.255.0
access-list outside_access_in extended permit tcp any host 192.168.2.101 eq ftp
access-list outside_access_in extended permit tcp any host 192.168.2.100 eq www
access-list VPN-FOO_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list inside_access_dmz extended permit tcp any object DMZ.net range 1 65535
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
ip local pool VPN-Pool 192.168.254.1-192.168.254.10 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (DMZ,outside) source static dmz-webserver interface service WWW WWW
nat (DMZ,outside) source static dmz-ftpserver interface service FTP FTP
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.10.10.0_28 NETWORK_OBJ_10.10.10.0_28 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_192.168.1.128_27 NETWORK_OBJ_192.168.1.128_27 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static NETWORK_OBJ_192.168.254.0_28 NETWORK_OBJ_192.168.254.0_28 no-proxy-arp route-lookup
nat (outside,outside) source dynamic NET-VPNPOOL interface
nat (inside,outside) dynamic interface
nat (DMZ,outside) dynamic interface
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 86.62.136.44 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
aaa authorization exec authentication-server
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.1.1 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
6c2527b9 deb78458 c61f381e a4c4cb66
quit
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 30
console timeout 0
management-access inside
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
dhcpd domain inside-sport.no
dhcpd auto_config outside
dhcpd address 192.168.1.20-192.168.1.49 inside
dhcpd dns 192.168.1.11 192.168.1.12 interface inside
dhcpd domain inside-sport.no interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp authenticate
ntp server 193.150.22.7 source outside
webvpn
group-policy VPN-FOO internal
group-policy VPN-FOO attributes
dns-server value 192.168.1.11 193.75.75.193
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN-FOO_splitTunnelAcl
default-domain value inside-sport.no
username polkadott password 12332131 encrypted privilege 15
username afrocircus password 123132 encrypted privilege 15
username foobar password sdafsdfsda encrypted
username foobar attributes
service-type remote-access
username barfoo password 1313131 encrypted privilege 0
username barfoo attributes
tunnel-group VPN-FOO type remote-access
tunnel-group VPN-FOO general-attributes
address-pool VPN-Pool
default-group-policy VPN-FOO
tunnel-group VPN-FOO ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:f3b732b91e291d6ad7ae12aaa271b31b
: end
Output of show version
Cisco Adaptive Security Appliance Software Version 8.4(2)
Device Manager Version 6.4(5)
Compiled on Wed 15-Jun-11 18:17 by builders
System image file is "disk0:/asa842-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 230 days 23 hours
Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode : CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.06
Number of accelerators: 1
0: Int: Internal-Data0/0 : address is ccef.4892.00b0, irq 11
1: Ext: Ethernet0/0 : address is ccef.4892.00a8, irq 255
2: Ext: Ethernet0/1 : address is ccef.4892.00a9, irq 255
3: Ext: Ethernet0/2 : address is ccef.4892.00aa, irq 255
4: Ext: Ethernet0/3 : address is ccef.4892.00ab, irq 255
5: Ext: Ethernet0/4 : address is ccef.4892.00ac, irq 255
6: Ext: Ethernet0/5 : address is ccef.4892.00ad, irq 255
7: Ext: Ethernet0/6 : address is ccef.4892.00ae, irq 255
8: Ext: Ethernet0/7 : address is ccef.4892.00af, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8 perpetual
VLANs : 3 DMZ Restricted
Dual ISPs : Disabled perpetual
VLAN Trunk Ports : 0 perpetual
Inside Hosts : 10 perpetual
Failover : Disabled perpetual
VPN-DES : Enabled perpetual
VPN-3DES-AES : Enabled perpetual
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 10 perpetual
Total VPN Peers : 25 perpetual
Shared License : Disabled perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
UC Phone Proxy Sessions : 2 perpetual
Total UC Proxy Sessions : 2 perpetual
Botnet Traffic Filter : Disabled perpetual
Intercompany Media Engine : Disabled perpetual
This platform has a Base license.
12-21-2012 12:44 AM
To my understanding you dont really need to configure the default route on the ASA itself if you are using DHCP on the "outside" interface to get the IP address from the ISP.
You can configure a "setroute" parameter at the end of the "ip address dhcp" command so that the DHCP will automatically set the default route for your when it gets an address from the DHCP server.
In your case the interface "outside" could look something like this
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
I can't see that the reason for some web sites not loading would be the firewall. Atleast I very rarely run into such problematic situations. If you want to investigate the thing more yourself you can use the ASDM Monitor/Logging to see what happens to those connections. You can also configure packet capture on the ASA itself and later open the capture file on Wireshark and confirm if there is anything coming from the webserver to your LAN host.
Have you confirmed that there is no problem related to DNS that could cause this?
You can also use the command "packet-tracer" to test the connection you are attempting. The output of the command will tell you what the ASA does to the packet/connection attempt and this way you can rule out alot of things.
Command format is the following:
packet-tracer input inside tcp x.x.x.x aaaa y.y.y.y bbbb
Where
- Jouni
12-21-2012 02:10 AM
Thanks for telling about the setroute, I have added it and since I had rebooted/reloaded the 5505 after this first question, I am now able to get online again...
Well, I have tried the packet-tracer, and the funny thing it that it reports that everything is OK. Something is odd though.
On some sites it could be that the information it sends to another domain stops loading of the page....
the ip in use is for www.digi.no
And as you may have noticed - I have access to this site ...
packet-tracer input inside tcp 192.168.1.8 80 82.117.50.1$
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in 0.0.0.0 0.0.0.0 outside
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: NAT
Subtype:
Result: ALLOW
Config:
Dynamic translate 192.168.1.8/80 to 86.62.136.44/250 <- the IP outside is not real (as in fake)
Phase: 4
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 18241, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
12-21-2012 02:37 AM
I can't see that the ASA would be the problem here (according to the avobe)
I would monitor through ASDM real time logging to check what connections the computer takes when connecting and what happens to those connections. Looking at your configuration you have done this before as there is the "logging asdm informational" that ASDM inserts to the configuration.
And as I said you can also do a packet capture on the ASA itself to see what traffic is going to and from the LAN host. Then again if you have never done this or looked at packet captures it might not be that usefull. Though naturally if you can take the capture and provide the file here on the forums someone can look through it.
I never really remember which device type and software supported which type of packet capture configuration (differences with FWSM and ASAs and probably the software levels alone too) BUT you might be able to configure it like this
Capture and ACL name might be a bit missleading since the below configuration captures all TCP/UDP traffic but this way you will see almost everything coming from the LAN host
access-list CAPTURE-WEB-TRAFFIC permit ip host
access-list CAPTURE-WEB-TRAFFIC permit ip any host
capture CAPTURE-WEB-TRAFFIC type raw-data access-list CAPTURE-WEB-TRAFFIC interface inside buffer 33500000 circular-buffer
You can copy it to some local computer with the command
copy /pcap capture:CAPTURE-WEB-TRAFFIC tftp://
You can show how much data has been captured by issuing the command
"show capture"
You can show the captured data with the command
"show capture
You can remove the capture with the command (which will also remove the captured data on the firewall)
"no capture
And just to make sure, is every type of connections having problems when connecting to the Internet? Do you expirience problems with all the different sites you use? Have you made sure that there is no problem with the actual Internet connection? (For example a continuous PING/ICMP from some LAN host to some IP address on the Internet (ISP DNS servers perhaps etc)
- Jouni
12-21-2012 02:52 AM
I did a wget to www.digi.no and in the capture I am seeing this:
5965: 11:47:13.287948 802.1Q vlan#1 P0 192.168.1.22.56369 > 74.125.143.109.993: . ack 4203439682 win 331
5966: 11:47:13.289779 802.1Q vlan#1 P0 192.168.1.22.33903 > 81.27.47.164.143: P 1147057306:1147057319(13) ack 4094693130 win 331
5967: 11:47:13.317488 802.1Q vlan#1 P0 81.27.47.164.143 > 192.168.1.22.33903: P 4094693130:4094693156(26) ack 1147057319 win 91
5968: 11:47:13.317717 802.1Q vlan#1 P0 192.168.1.22.33903 > 81.27.47.164.143: . ack 4094693156 win 331
5969: 11:47:13.335660 802.1Q vlan#1 P0 192.168.1.22.33905 > 81.27.47.164.143: P 1946962938:1946962951(13) ack 3747978698 win 190
5970: 11:47:13.362942 802.1Q vlan#1 P0 81.27.47.164.143 > 192.168.1.22.33905: P 3747978698:3747978724(26) ack 1946962951 win 91
5971: 11:47:13.363094 802.1Q vlan#1 P0 192.168.1.22.33905 > 81.27.47.164.143: . ack 3747978724 win 190
5972: 11:47:13.387751 802.1Q vlan#1 P0 192.168.1.22.46864 > 192.168.1.1.22: P 3937008649:3937008697(48) ack 2079733693 win 65535
5973: 11:47:13.387827 802.1Q vlan#1 P0 192.168.1.1.22 > 192.168.1.22.46864: . ack 3937008697 win 32768
5974: 11:47:13.388987 802.1Q vlan#1 P0 192.168.1.1.22 > 192.168.1.22.46864: P 2079733693:2079733741(48) ack 3937008697 win 32768
5975: 11:47:13.391062 802.1Q vlan#1 P0 192.168.1.22.46864 > 192.168.1.1.22: . ack 2079733741 win 65535
5976: 11:47:13.391916 802.1Q vlan#1 P0 192.168.1.1.22 > 192.168.1.22.46864: P 2079733741:2079733789(48) ack 3937008697 win 32768
5977: 11:47:13.392618 802.1Q vlan#1 P0 192.168.1.1.22 > 192.168.1.22.46864: P 2079733789:2079733853(64) ack 3937008697 win 32768
5978: 11:47:13.392664 802.1Q vlan#1 P0 192.168.1.22.46864 > 192.168.1.1.22: . ack 2079733789 win 65535
Some more setup.
In the host server that runs some guest virtual box virtual servers I have this route.
route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.254.0 192.168.1.1 255.255.255.0 UG 0 0 0 eth0
192.168.2.0 0.0.0.0 255.255.254.0 U 0 0 0 eth1
0.0.0.0 192.168.2.1 0.0.0.0 UG 0 0 0 eth1
where 192.168.2.1 is the IP for the DMZ
On the two DNS-servers I have, the routing table looks like this:
routing table
0.0.0.0 192.168.1.1 0.0.0.0 UG 100 0 0 eth0
