Cisco ASA 5505 doesn't forware incoming connection to LAN
Jose Pena
Hello everybody.
I just got a Cisco asa 5505 with the next OS and ASDM info
ASA 5505 OS 8.4(3) ASDM 6.47
I configured and enter all rules to allow incoming traffic to LAN but it's not working also, I have one host inside that is configured in a second IP and create the rule to allow traffic to it but it doesn't work too.
Problem 1
I have VNC running in port 5900 tcp and I want to connect from Internet using port 6001 and this has to forware the connection to the real VNC port. In the configuration I have a few host with the same configuration but I use different outside port to get it.
Problem 2.
I have a second IP with services: SMTP, HTTP, HTTPS and port 444 all TCP forwarding to a server in the LAN.
Facts:
SMTP.
Every time that I do telnet to the second IP looking for the SMTP port, the firewall doesn't let the incoming connection goes through and the LOGGING screen doesn't how that connection.
PORT 6001 (outside)
this port is configured to work with the IP in the outside internface and it was to send the incoming connection to a host inside to the real port 5900.
Can any one check my configuration if I'm missing anything? for sure I'm but I didn't find it. Bellow is the configuration, I masked the Public IPs just left the last number in the IP, also I left the LAN network to see better the configuration.
I will appreciate any help.
Thanks a lot..
CONFIGURATION.
: Saved
ASA Version 8.4(3)
hostname saturn1
domain-name mydominio.com
enable password SOMEPASS encrypted
passwd SOMEPASS encrypted
names
name 192.168.250.11 CAPITOLA-LAN
name 192.168.250.15 OBIi110-LAN
name 192.168.250.21 DRP1260-LAN
name 192.168.250.22 HPOJ8500-LAN
name 192.168.250.30 AP-W77-NG-LAN
name 192.168.250.97 AJ-DTOP-PC-LAN
name 192.168.250.96 SWEETHEART-PC-LAN
name 192.168.250.94 KIDS-PC-LAN
name XX.YY.ZZ.250 EXTERNALIP
name XX.YY.ZZ.251 EXTERNALIP2
name XX.YY.ZZ.1 GTWAY
dns-guard
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.250.2 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address EXTERNALIP 255.255.255.0
boot system disk0:/asa843-k8.bin
ftp mode passive
dns server-group DefaultDNS
object network CAPITOLA-LAN
host 192.168.250.11
object network EXTERNALIP
host XX.YY.ZZ.250
description Created during name migration
object network CAPITOLA-PUBLIC
host XX.YY.ZZ.251
object network capitola-int
host 192.168.250.11
object network capitola-int-vnc
host 192.168.250.11
object network aj-dtop-int-vnc
host 192.168.250.97
object network sweetheart-int-vnc
host 192.168.250.96
object network kids-int-vnc
host 192.168.250.94
object network VPNNetwork
subnet 10.10.20.0 255.255.255.0
object network InsideNetwork
subnet 192.168.250.0 255.255.255.0
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network capitola-int-smtp
host 192.168.250.11
object-group service capitola-int-smtp-service tcp
port-object eq smtp
object-group service capitola-int-services tcp
port-object eq smtp
port-object eq https
port-object eq www
port-object eq 444
object-group service capitola-int-vnc-service tcp
port-object eq 6001
object-group service aj-dtop-int-vnc-service tcp
port-object eq 6002
object-group service sweetheart-int-vnc-service tcp
port-object eq 6003
object-group service kids-int-vnc-service tcp
port-object eq 6004
access-list incoming extended permit icmp any any
access-list incoming extended permit tcp any object capitola-int object-group capitola-int-services
access-list incoming extended permit tcp any object capitola-int-vnc object-group capitola-int-vnc-service
access-list incoming extended permit tcp any object aj-dtop-int-vnc object-group aj-dtop-int-vnc-service
access-list incoming extended permit tcp any object sweetheart-int-vnc object-group sweetheart-int-vnc-service
access-list incoming extended permit tcp any object kids-int-vnc object-group kids-int-vnc-service
access-list incoming extended permit tcp any object capitola-int-smtp object-group capitola-int-smtp-service
access-list split-tunnel standard permit 192.168.250.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any object VPNNetwork
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool vpnpool 10.10.20.1-10.10.20.50 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (inside,any) source static any any destination static VPNNetwork VPNNetwork no-proxy-arp
nat (any,any) static XX.YY.ZZ.251
nat (inside,outside) static interface service tcp 5900 6001
nat (inside,outside) static interface service tcp 5900 6002
nat (inside,outside) static interface service tcp 5900 6003
nat (inside,outside) static interface service tcp 5900 6004
nat (inside,outside) dynamic interface
nat (any,outside) static interface service tcp smtp smtp
access-group incoming in interface outside
route outside 0.0.0.0 0.0.0.0 GTWAY 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http server idle-timeout 2
http server session-timeout 1
http 192.168.1.0 255.255.255.0 inside
http CAPITOLA-LAN 255.255.255.255 inside
http AJ-DTOP-PC-LAN 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh CAPITOLA-LAN 255.255.255.255 inside
ssh AJ-DTOP-PC-LAN 255.255.255.255 inside
ssh timeout 15
console timeout 0
vpn-addr-assign local reuse-delay 2
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username admin password SOMEPASS encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:036b82d3eb5cffc1c65a3b381246d043
: end
Jose, your fix to problem 1 allows all access from the outside, assuming you applied the extended list to the outside interface.  Try to be more restrictive than an '...ip any any' rule for outside_in connections.  For instance, this is what I have for incoming VOIP (access list and nat rules):
access list rule:
access-list outside_access_in extended permit udp any object server range 9000 9049 log errors
nat rule:
nat (inside,outside) source static server interface service voip-range voip-range
- 'server' is a network object *
- 'voip-range' is a service group range
I'd assume you can do something similar here in combination with my earlier comment:
access-list incoming extended permit tcp any any eq 5900
Can you explain your forwarding methodology a little more?  I'm by no means an expert on forwarding, but the way I read what you're trying to do is that you have an inbound VNC request coming in on 5900 and you want the firewall to figure out which host the request should go to.  Or is it vice-versa, the inbound VNC request can be on port 6001-6004 ?
justinfarmer
If I understand you right, this sounds like a nat routing issue, you have the static nat lines, but they don't know where to forward to.  Try something like:
nat (inside,outside) source static interface service
Good Luck!
Justin,
I tried but it doesn't work, any other suggestion.
I had reviewed the configuration 5 times. I configured other device and I did the same configuration except with my IPs and nothing works.
Do you know if there is any other firmware update apart of the OS and ASMD version for this firewall?
Thanks for your help.
Jos.
Jose Pena
Problem 1 Solution
Found a solution for the incoming connections to the Interface, I added the next line
access-list incoming extended permit ip any any
and all open port forward the incoming connection to the respective host in LAN
Can anyone confirm if I'm not opening more port of what I allowed traffic? Thanks.
Problem 2:
I didn't find the solution yet but I'm still looking.
Problem 3
With the same configuration, I don't have LAN traffic to Internet. I can do ping and I can go direct to the IP of the server to see a website but not to the FQDN,
a) How can I allow all LAN traffic goes to Internet?
b) Apparently, when I do nslookup the software doesn't resolve even when I have the server working and the service running. If I install an old router that i'm replacing, all traffic works well but not with current ASA configuration.
Any suggestion.
Have a good nite/day.
Jos P
Now, 2 questions more
access list rule:
nat rule:
