Cisco ASA device and "nlp_int_tap" interface
alfio.pafumi
Hi All,
I am trying to understand what traffic is usually expected to flow through the "nlp_int_tap" interface in an ASA device.
The only reference I found, so far, looking at Cisco docs, is that this interface is used for system communications:
https://www.cisco.com/c/en/us/td/docs/security/firepower/command_ref/b_Command_Reference_for_Firepower_Threat_Defense/s_1.html
(searching in that page for “nlp_int_tap” there is a very brief note, mentioning that).
Is it correct?
Is also correct to assume that no business related network traffic should, usually, use that interface?
Thanks for any help!
A.
patoberli
Have you found this ever out?
Asking because I just replaced my old ASAs with new Firepower 2110 ASA models for VPN access.
Most client traffic seems to use the source interface named 'nlp_int_tap', but I haven't named an interface such. I did mostly copy&paste the old configuration to the new device.
I'm having the same problem and it generates a lot of traffic. did you figure out what this is?
I have since upgraded to 9.12(3) and haven't seen this issue anymore. I'm not sure though, if the upgrade was the solution or something else I changed in the past.
fly
Level 2
Level 2
we found many drops on this interface
Traffic Statistics for "nlp_int_tap":
40900625 packets input, 2868084192 bytes
833962 packets output, 23351096 bytes
40066668 packets dropped  <<<<<<======
version is 9.12(4)
