cisco ASA-X SSL inspection(known-key) Problem
i have ASA5555-X with firepower module
i use ASDM for manage ASA and use FMC(6.4.0.4) for manage FIREPOWER
(use inline mode for asa traffic to firepower)
i have a web server in DMZ
i config Decrypt-Known key method for outbound traffic that access to my webserver in DMZ
i add my webserver certificate and private key in PKI / INTERNAL CERTS in FMC
i create rule in ssl and so i call ssl policy in Access Control Policy
i think all configure is ok
but i can not see my website from outside
i check event log
action =block
reaseon =ssl block
ssl flow error = unsupported ec curve (0xb9001d57)
can anyone help me ?
2 Accepted Solutions
Marvin Rhoads
It appears you are hitting this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn57284?rfs=iqvred
A work around is included in the bug notes.
Can you please confirm that your mail server uses the same wildcard certificate as the other servers?
7 Replies 7
Marvin Rhoads
thanks for solution
it works fine for my websites inspect
but
so i have a microsoft exchange  server that i want inspect it too
, but i have problem for my microsoft exchange webpage after knownkey method
can you help me about it , too ?
Marvin Rhoads
The entries in your mail4.jpg attachment indicate "Invalid Issuer". Have you imported the issuing CA's certificate as a trusted certificate?
Unfortunately, I do not understand what you mean
i have a one wildcard certificate for all subdomain
and i import these ( certificate and private key) in  INTERNAL CERTS
and all websites are ok except exchange webpage
i dont have import ca certificate as a trusted certificate !!
Unfortunately , i have no information about import ca certificate as  a trusted certificate
yes sir
thanks alot
the problem was solved
