Cisco FP 1120 FDM not able to register Smart license
akrimpma
Again, an old issue where I did not find a solution when searching in the community.
FP 1120 is not able to access Cisco's smart licensing server.
Here is my configuration:
> show network
===============[ System Information ]===============
Hostname                  : zzz
Domains                   : xxx.yyy.com
DNS Servers               : 192.168.2.25
Management port           : 8305
IPv4 Default route
  Gateway                 : 192.168.2.6
  Netmask                 : 0.0.0.0
==================[ management0 ]===================
State                     : Enabled
Link                      : Up
Channels                  : Management & Events
Mode                      : Non-Autonegotiation
MDI/MDIX                  : Auto/MDIX
MTU                       : 1500
MAC Address               : 68:87:C6:71:9C:00
----------------------[ IPv4 ]----------------------
Configuration             : Manual
Address                   : 192.168.2.19
Netmask                   : 255.255.255.0
----------------------[ IPv6 ]----------------------
Configuration             : Disabled
===============[ Proxy Information ]================
State                     : Disabled
Authentication            : Disabled
> show interface ip brief
Interface                  IP-Address      OK?           Method Status      Protocol
Internal-Data0/0           unassigned      YES           unset  up          up
Ethernet1/1                192.168.0.6     YES           manual up          up
Ethernet1/2                192.168.1.6     YES           manual admin down  down
Ethernet1/3                unassigned      YES           unset  admin down  down
Ethernet1/4                unassigned      YES           unset  admin down  down
Ethernet1/5                unassigned      YES           unset  admin down  down
Ethernet1/6                unassigned      YES           unset  admin down  down
Ethernet1/7                unassigned      YES           unset  admin down  down
Ethernet1/8                unassigned      YES           unset  admin down  down
Ethernet1/9                192.168.2.6     YES           manual up          up
Ethernet1/10               unassigned      YES           unset  admin down  down
Ethernet1/11               unassigned      YES           unset  admin down  down
Ethernet1/12               unassigned      YES           unset  admin down  down
Internal-Control1/1        unassigned      YES           unset  up          up
Internal-Data1/1           169.254.1.1     YES           unset  up          up
Internal-Data1/2           unassigned      YES           unset  up          up
Management1/1              unassigned      YES           unset  up          up
> show route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S*       0.0.0.0 0.0.0.0 [1/0] via 192.168.0.1, outside
C        192.168.0.0 255.255.255.0 is directly connected, outside
L        192.168.0.6 255.255.255.255 is directly connected, outside
C        192.168.2.0 255.255.255.0 is directly connected, inside
L        192.168.2.6 255.255.255.255 is directly connected, inside
> ping 192.168.2.25
Sending 5, 100-byte ICMP Echos to 192.168.2.25, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
> ping system 192.168.2.25
Command execution timed out. Please try again.
> ping 192.168.2.19
Sending 5, 100-byte ICMP Echos to 192.168.2.19, timeout is 2 seconds:
Success rate is 0 percent (0/5)
> ping system 192.168.2.19
> ping google.com
Sending 5, 100-byte ICMP Echos to 142.251.143.78, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/22/30 ms
> ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
I also used 192.168.2.23 as an alternative gateway for the management interface, it did not work either (this is another way to the internet).
Does anybody has a clue how to fix this?
Thx,
Andreas
Marvin Rhoads
When your "ping system 192.168.2.25" failed, that indicates your configured name server (DNS) is not reachable from your management interface.
The management interface must have Internet connectivity, the ability to resolve Cisco's FQDNs and be able to reach them via https.
You must also have a relatively recent release or patch to account for Cisco having updated the Certificate Authority (CA) used by the licensing servers.
Well, the DNS server resolves FQDNs to IP addresses appropriately - but only through the data interface. As the internal DNS server is reachable through the data interface, I believe it is more or less a management port issue (configuration?). I have added a small picture showing the current environment.
akrimpma
Just a small enhancement:
> traceroute system 192.168.2.25
traceroute to 192.168.2.25 (192.168.2.25), 30 hops max, 60 byte packets
1 AKF206 (192.168.2.19) 2998.101 ms !H 2998.048 ms !H 2998.047 ms !H
PING 192.168.2.25 (192.168.2.25) 56(84) bytes of data.
From 192.168.2.19 icmp_seq=1 Destination Host Unreachable
^C
--- 192.168.2.25 ping statistics ---
6 packets transmitted, 0 received, +1 errors, 100% packet loss, time 4999ms
pipe 4
PING 192.168.2.19 (192.168.2.19) 56(84) bytes of data.
64 bytes from 192.168.2.19: icmp_seq=1 ttl=64 time=0.073 ms
64 bytes from 192.168.2.19: icmp_seq=2 ttl=64 time=0.055 ms
64 bytes from 192.168.2.19: icmp_seq=3 ttl=64 time=0.055 ms
^C
--- 192.168.2.19 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.055/0.061/0.073/0.008 ms
It seems that there is a path to the DNS server
