02-26-2009 08:24 AM - edited 02-21-2020 03:19 AM
We have LMS 3.0.1 installed with DFM 3.0.4 The devices are showing Questioned with Error code "SNMP timeout" with no specific reason. The snmpwalk is coming for the device as I checked with snmpwalk command. The only device discovered as"known" has ICMP permitted from Server to device and no other device has. They only have SNMP permit. Can this affect the dicovery?? or what else can I try....Please suggest!!
Rgds
Solved! Go to Solution.
02-26-2009 10:13 AM
Yes. DFM requires that all devices be both SNMP and ICMP reachable. DFM uses ICMP to verify reachability to all IP addresses on the device. However, at the very least, the address by which you manage the device MUST be ICMP reachable.
02-26-2009 10:13 AM
03-02-2009 04:44 AM
Thanks Joe. I have communicated the same further.
