DFM device discovery issue "Devices stuck in Questioned state"
smitapande83
We have LMS 3.0.1 installed with DFM 3.0.4 The devices are showing Questioned with Error code "SNMP timeout" with no specific reason. The snmpwalk is coming for the device as I checked with snmpwalk command. The only device discovered as"known" has ICMP permitted from Server to device and no other device has. They only have SNMP permit. Can this affect the dicovery?? or what else can I try....Please suggest!!
Rgds
Joe Clarke
Yes. DFM requires that all devices be both SNMP and ICMP reachable. DFM uses ICMP to verify reachability to all IP addresses on the device. However, at the very least, the address by which you manage the device MUST be ICMP reachable.
Joe Clarke
Thanks Joe. I have communicated the same further.
