Difference between Signatures and Rules
Sean_mercer
Hello Cisco Peeps
We have just deployed Firepower in our Network using vFMC and various software based and hardware based sensors.  Im reading cisco documentaion about 'Rules' and looking at Intrusion rules on the FMC. Are rules like IPS signatures ? and if so what is the Differnece between a Rule in Firepower and an ips Signature?
Cheers
Sean :)
Veronika Klauzova
Dear Sean,
Firepower/IPS rules are in other words signatures or patterns based on which we try to match known attacks against traffic flows that are traversing through the sensors. Each rule has it's own signature unique identifier aka SID.
Whenever Cisco publish a new rules that can protect networks against new attacks they are being provided in signatures updates which we call also SRU's/Sourcefire Rule Updates. So make sure that you are always up to date, it is good idea to consider to schedule SRU updates on periodic basis.
Rules in Firepower 'world' are based on Snort syntax, in order for you to learn about rules syntax you can refer to any of Snort/Sourcefire user manual: http://manual-snort-org.s3-website-us-east-1.amazonaws.com/
IPS rules on old Cisco platforms were using custom Cisco proprietary engine, but it was also using signature based patterns, they were just having different syntax.
Let me know if more questions comes to your mind on this topic.
Best regards,
Veronika
Adding some additional resource of signature explanation: https://www.snort.org/faq/what-is-a-signature
Hello Veronika,
I have a question around ACL counter on FTDs,
I Was told by one of the TAC engineers that whenever you deploy the policies from FMC ACLs count get cleared , the reasoning behind it was the SNORT process  that restarts when a new policy get deployed.
I have IPS base policy as ( balanced security and connectivity ) and its running in IPS mode.
I want your thought on this please.
also, is there any way to clear a specific ACL rule ( like we used to do in Cisco ASA) ,, clear access-list ( ACL name ) counters,, is there any similar command in FTD  , FTD is having only one ACLs in background and that is CSM_FW_ACL_ so if we clear this that will clear the counter of all the rules.
Thanks for your response..
