Failover setting on ASA with CSC module
Hi there ... I'm a single ASA-5510 with CSC module ... I want to pair it for active/standby mode for failover .... can it be done if second ASA doesn't have the module? Can I assume the in case of a failover, the traffic won't be checked, and primary does in case CSC module fails?
Julio Carvajal
No, exact hardware must be used.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
lcambron
Level 3
Level 3
Hello Gustavo,
You can remove the module from the primary ASA, and setup failover with no CSC at all, but as Julio stated the hardware must be the same.
Felipe.
