Firepower 7.42 issue interface Management0 has no link
Lee Dress
Level 5
Level 5
I'm in the process of upgrading all of my firepower devices from 7.2.8 to 7.4.2 as it is the suggested release.
we use the data interfaces as the management interface for most remote devices.
As I upgrade each one, I'm now presented with a critical warning the Interface Management0 has no link.
I have turned off interface statistics in the health monitor policy, and all devices show green on the health monitor page.
but the drop down notification screen still shows 6 critical warnings. See attached screenshots.
all devices are working normally.  VPN tunnels and traffic are not affected.
I have a case open with TAC, they're not getting back to me till Monday.
I thought maybe someone here might know the solution.
Lee Dress
Level 5
Level 5
I found it.
you need to go to Devices / Device Management,
Select the Device, and go to Health / Excluded
Check Interface status in this screen and the warning goes away.
14 Replies 14
balaji.bandi
that is ok that is complaining about no traffic, that is not to worry bit.
coupld be cosmetic bug.
BB
Marvin Rhoads
If you are not using the management interface, you can exclude it from monitoring - use the System > Health > Exclude menu
the management interface is not listed as something to exclude in the menu.
I already have tried interface statistics, but that doesn't clear it up in the drop down notification menu.
Lee Dress
Level 5
Level 5
I found it.
@Lee Dress that option will exclude all interface monitoring from health policy and associated alerts. 7.4+ will allow you to do a custom exclusion to remove only a subset of interfaces - such as management only - while continuing to monitor all others.
I do not see the option in my system health exclude screen.
I see it now.  maybe because all of my devices weren't upgraded to 7.4.2 it wasn't showing.
trying your suggestion now.
this didn't work.  the exclusion is for Management 1/1 but my warning is for management0.  I still have health warnings on all the devices that use the Data interfaces as the management interface.   there is no option for "management0" in the list.
I just checked a deployment with remote 1010s with FTD 7.2.8 managed via their data interface. management0 in clish (ftd cli shell) is equivalent to Management1/1 or "diagnostic" in the LINA shell (system support diagnostic cli).
In any case, your settings there should result in the exclusion of those alerts (assuming the exclusion policy had been associated to the device and deployed).
If that's not working, a TAC case might be a good next step.
Okay I think I will open a TAC.
Only after you enable module level exclusion and then Network Card / Interface move the slider for Interface Statistics will you see the option to select individual interfaces.
The screenshot below is on FMC 7.6, but I have confirmed it is available on 7.2.x and 7.4.x as well.
I tried that with Management 1/1 but when I turned off my exclusions the warnings for management0 came back.
thank you for trying to help.  I appreciate it.
The same for me. I do not see these option. I can only check button for interface status. But no selection. Also my FMC looks totally different.
But still even with interface status selected, the error message does not disappear.
[cid:image001.png@01DB1E47.85BC19D0]
mchammer7
Frequent Visitor
Frequent Visitor
We excluded the interface status in the health policy, but the warning in FMC is still shown in 7.4.2. With 7.2.8 no warnings were shown. Any suggestions ?
