FireSIGHT/POWER vs FTD
Netmart
Level 3
Level 3
I was wondering, if it is possible to upgrade an existing FireSIGHT/POWER platform running on ASA 5545x to FirePOWER Threat Defense (FTD).
Current software version of FireSIGHT and FirePOWER module are 6.2.0.5.
Please advise.
Thank you.
Marvin Rhoads
Upgrade, no. Convert, yes.
An ASA appliance with ASA software and a Firepower service module is essentially running two separate operating systems - think of them as two hosts connected via the internal backplane interface.
An ASA appliance running FTD is a single unified operating system.
To move from one to the other you need to reimage the appliance - there are instructions for doing so here:
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/reimage/asa-ftd-reimage.html
But there are also important distinctions and caveats to evaluate prior to making such a decision (capabilities, licensing, management model etc.). You should work with your Cisco partner or investigate these carefully first.
