FMC 1000 ( 6.2.2 to 6.2.3 ) / Upgrade Problem
Hi all ,
I need you help please ,
Briefly , I have two FMC 1000 ( HA ) and I have to upgrade them from current 6.2.2 to 6.2.3.
I got the upgrade image from Cisco Website and I upload the package to Standby FMC
System >> Update >> Upload  >> ( I got the successful message )
but I couldn't find it into update list file , did I miss something ?
Dear All ,
This problem has been solved by  :
-  when I download the package from cisco website there is a space in the file name ( make sure to rename it ) .
- doing the upgrade through CLI  ( the package is not appear in GUI interface but you can find it using CLI commands .
Thanks for providing your resolution. I hadn't seen that issue before.
Perhaps it has to do with the browser you used for downloading?
Dear my friend ,
I already tried many browsers with same result , the image is actually uploaded and you can see it only through CLI ^_^
Regards ,
