07-04-2013 07:34 PM - edited 03-11-2019 07:07 PM
Hi Everyone,
I am trying to FTP from the PC behind the DMZ interface.
I have config the ACL to allow FTP from outside interface direction is outside.
I can make the FTP work by config of ACL on the DMZ interface but i want to test it so that it can work from my PC behind DMZ interface when i apply ACL on the outside interface direction is out.
I have attached the asa config.
Need to know if there is any way under current config that FTP can work without applying ACL to DMZ interface?
Solved! Go to Solution.
07-04-2013 10:32 PM
I can't look at your config at the moment (doesn't work on the iPad), but one alternative to an ACL on the DMZ interface could be to use a global ACL.
07-05-2013 01:37 AM
Apply that acl in incoming direction on outside interface.
no, the ASA is a statefull Firewall with FTP-Inspection. You never need an incoming ACL in the outside interface for outbound FTP when you have a proper config.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
07-04-2013 10:32 PM
07-05-2013 01:11 AM
Hi Mahesh,
Cheers
Pankaj
07-05-2013 01:37 AM
07-05-2013 07:47 AM
Hi Karsten,
Your answers are good to read and they have so much knowledge.
For time being i allowed ftp to any destination from DMZ but on outbound interface direction out i have restricted it with
certain IP which are allowed.
Best regards
Mahesh
