H323 Inspect activated and phone call works
Luis Carranza
Greetings people!!
I open this post to ask you for your help, I got a problem yesterday with a customer that says that the calls from a CISCO IP Phone 7961 to an Alcatel 4018 IP Touch didn't work, well the phone rings but there's no voice; I manage a CISCO ASA version 8.2(1) and I was checking the Inspection Rules in the Service Policy Rules section and when you open the inspection_default at the Rule Actions tab I find that the H.323 H.225 and H.323 RAS box wasn't checked so I ask to the customer to made a test and the same problem happen so I checked both box and again ask to the customer for a test and it works.
I was talking to a partner and he said that maybe this Inspect fix some signaling parameters of this protocol that can't work fine behind of a firewall. but I wan't know how it REALLY works, so those anybody had any answer to this.?
varrao
Level 10
Level 10
Hi Luiz,
Please go through this very good doc for VOIP traffic, this should answer your questions:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
Hope this helps.
Varun
Varun Rao
