06-13-2007 09:19 PM - edited 02-21-2020 01:34 AM
Hi, my internet is a IP-8 PPPoE session. Now I try to install PIX515E failover but don't know how to config. If I use fix IP there is no default gateway in PPPoE setting. Somebody can help me?
06-15-2007 09:16 AM
Hello Amigo.
one of the failover requirements is to have static ip's configured. PPPOE is a dynamic way to get ip's, therefore failover will not support this.
06-15-2007 08:04 PM
You will need ASA ver 7.2 in order to do PPPoE. Also if it is a dynamic PPPoE connection, you may need the "setroute" command to set default route. See example below for dynamic PPPoE:
interface Ethernet0/0
nameif outside
security-level 0
pppoe client vpdn group bellsouthDSL
ip address pppoe setroute
vpdn group bellsouthDSL request dialout pppoe
vpdn group bellsouthDSL localname cisco@bellsouth.net
vpdn group bellsouthDSL ppp authentication pap
vpdn username cisco@bellsouth.net password 7779311
06-17-2007 04:24 PM
Thanks you very much! Because upgrade to high version is the next project so I will ask vender to change pppoe to fixed IP. Thanks!
