how does a cisco asa increment an acl's hit counts in aces using object-groups vs. the expanded ace entries?
Cody Hartley
Beginner
Beginner
I have a cicso asa 5510 running ASA version 9.1(4) and the following ACE when expanded shows a "0 hit count" acl line that is expanded to ace's that have hit counts. Is this a bug???
access-list outside_acl line 1 extended permit object-group OG-SIP_SVCS 1.1.1.1 255.255.255.255 object obj-inside-ip (hitcnt=0) 0x0fb61f6b
  access-list outside_acl line 1 extended permit tcp 1.1.1.1 255.255.255.255 host 192.168.1.1 eq sip (hitcnt=0) 0x5f1e7341
  access-list outside_acl line 1 extended permit udp 1.1.1.1 255.255.255.255 host 192.168.1.1 eq sip (hitcnt=3459) 0x80891f5c
  access-list outside_acl line 1 extended permit tcp 1.1.1.1 255.255.255.255 host 192.168.1.1 eq 5061 (hitcnt=0) 0x16e45ad0
Karsten Iwen
VIP Mentor VIP Mentor
VIP Mentor
I would consider that a bug. On my ACLs I often see the hitcount of the first line as the overall hitcount, but sometimes it doesn't match at all. So it's best to only look at the individual ACE-counters.
Recognize Your Peers
