10-15-2015 07:53 PM - edited 03-11-2019 11:45 PM
Hello Experts,
I need a help. In my network I have an ASA5505 running with several ACLs' for several other purpose. Is it possible to block BITTORRENT data transmission using ASA5505 alone? Or do I need to have any other firewalls/software along with ASA5505 to block it?
I have noticed some basic port usage by the torrent client and based on that the following ACEs' I have created; but it seems to be no use. Because, even though sometimes torrent transmissions are disrupted, but majorly it's communicating.
10 deny tcp any any eq 6969 (5984 matches)
20 deny udp any any eq 80 (115784 matches)
30 deny udp any any eq 1337 (1284 matches)
40 permit ip any any (5905084 matches)
Please help me or advice me regarding how can I stop BITTORRENT transmission on a full-swing.
Thanks in advance.
Samrat Bose.
Solved! Go to Solution.
10-15-2015 11:09 PM
Hi Samrat,
So basically FirePOWER is next gen firewall services which Cisco offers.
You can run FirePOWER on any 5500-x ASA. New firewalls such as 5506,5508,5516 comes pre-loaded with FirePOWER.
For more details you may refer:
http://www.cisco.com/c/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/datasheet-c78-733916.html
http://www.cisco.com/c/en/us/products/security/asa-firepower-services/models-comparison.html
Hope it helps!!!
R.Seth
Mark the answer as correct if it helps in resolving your query!!!
10-15-2015 09:21 PM
Hi Samrat,
As the BITTORRENT hops ports while downloading data so it is difficult to block it with ACLs.
You require application identification to identify BITTORRENT traffic. You can read more about FirePOWER services which can identify applications to control traffic.
R.Seth
10-15-2015 10:45 PM
Thank you for the advice, sincerely. Can you please tell me any other facts related to this FirePOWER.. Although I'll google it.
10-15-2015 11:09 PM
Hi Samrat,
Hope it helps!!!
R.Seth
10-15-2015 11:42 PM
Hi, it seems like I cannot use this with my 5505 firewall. Because (if I'm not wrong), the datasheet mentions that FirePower is applicable from 5506-X onwards.
10-16-2015 12:01 AM
Yes, you are right. The 5506 can be compared to old 5505 firewall in terms of capacity.
R.Seth
