IDS 4215 Connection issue
emad.mohamed
I have IDS device version (4215) trying to connected to VMS CISCO works version 2.5. all the other IDS devices that previously connected are version 4210, but only this one does NOT report any alarms. However, it shows that it is connected on the SEC MON. and IDS-IDM.
any idea?
thank you
r-sivanandan
What version of IDS software is running on 4215?
On VMS Machine open the IDS_EvsServer.log & IDS_Receiver.log files and see if there are any errors logged in there.
If all ok, then log on to the sensor. Do a show version and make sure all the processes are running fine.
If they are fine at the sensor end, then in the sensor console make sure that sensor indeed is producing alerts by 'Show events'
Cheers,
Rajesh
