Inter vlan routing issue
vijayarampm
I have created new VLAN for DVR's and it is connected with my core switch 3750G. I am able to ping DVR IP's from my core switch but the same was not able from my access switch from another vlan.
interface Vlan250
description """DVR"""
ip address 10.110.110.1 255.255.255.0
ip route 10.110.110.0 255.255.255.0 10.24.1.1(Vlan segment pointing to router).
Please confirm the cause for the inter valn routing issue.
17 Replies 17
Observed the misconfiguration of gateway IP in DVR and same has been corrected now. It is working from LAN and same needs to be tested through VPN.
What needs to be done to check via VPN ? Is static route of DVR VLAN segment in core switch pointing to Router will work ?
Hi there,
Yes you are correct, but you will also need a static route on Core1-3750-24-PoE directing traffic destined to the remote site subnets via the VPN.
It would be much easier to configure dynamic routing between your sites.
cheers,
Seb.
I have pointed one static route in my core switch to core router and now it is working. Thanks for your support.
