Is FDM enough for IPS configuration for FTD3110-HA-Bundle
adeebtaqui
Level 4
Level 4
Greetings,
Kindly advise if  FDM is enough for IPS configuration for FTD3110-HA-Bundle as DMZ firewall.
5 Replies 5
FMC from my view is better
MHM
balaji.bandi
You need to look what FDM and FMC can do, if that FDM able to do that task for you, you can do.
FTD is as zones -
BB
Cristian Matei
   Is it gonna work? Yes. If you have the budget, add FMC on top of it for both simplified and centralized management.
Best,
Cristian.
Friends don't let friends use FDM.  Deploy FMCv or use cdFMC.  You will QUICKLY run into a feature you want that is just not available on FDM or requires API to configure.
I agree with @ahollifield although FDM would work in your case FDM does not fully support all the features that the FMC does. FMCv licenses are not expensive, so imo FMCv would be the way to go. However, if you don't want to go through the admin works of preparing the FMCv, host it on your hypervisor, maintain it, backups, etc then as @ahollifield mentioned you can explore the cloud delivered FMC option.
