Is there a similar entry to "management-interface inside" on FTD CDO
ABaker94985
The management system at our HQ reaches out to the inside interfaces of the branch firewalls through site-to-site VPN tunnels for both pings and SNMP, and on the firewalls running ASA firmware, we use "management-interface inside." Is there a similar command for the FTD/CDO? Is this a command that go in flex config? I've not been able to find documentation on how to get this inserted.
The system I'm currently working with is an ASA 5508-X running 6.6.1. The ACP is permitting this, but I'm also not sure if there is something on the control plane that needs to be opened up. Is there anything else I need to consider?
Thank you.
Thanks for the super fast response. That's exactly what I was looking for. Take care.
