ISA 3000 I/O contacts for red light kill switch ?
Ben0it
Hello, can the ISA 3000 be configured so that :
 - when an input contact becomes active, it can enable or disable some specific access lists (firewall rules).
 - when some specific access lists (firewall rules) are enabled or disabled, reflect that state on output contact to drive a towerlight in the machine (shop floor environment).
Typical need is for our operators to use a switch or push button on the electrical cabinet of the machine to allow/deny access to the machine network to remote connections (VPN typically) in case of supplier remote support.
Could this be achieved with the ISA 3000 family devices ?
Best regards,
Benoît.
0 Replies 0
