8024
Highlighted
Beginner
Issue regarding failover on an Active/Active ASA cluster with shared interfaces
Hello Community,
I have an issue regarding failover on an Active/Active ASA cluster with some shared interfaces. I have two ASA firewalls running 16 contexts, most "inside" and "outside" interfaces are shared between contexts and each context has at least one interface which is dedicated for that context.
All contexts are operating fine and failover works too. However, all interfaces which are shared between contexts are in the "Normal (Waiting)" state. An interface the belong to just one context is in the "Normal" state.
Output from "show failover" from the System context:
Context1/act# show failover
<removed details>
  This host:    Primary
                slot 0: ASA5520 hw/sw rev (1.1/8.2(5)) status (Up Sys)
                  Context01 Interface outside (x.x.0.132):   Normal (Waiting)
                  Context01 Interface inside  (x.x.230.43):  Normal (Waiting)
                  Context01 Interface dmz     (x.x.8.1):     Normal
                  Context02 Interface outside (x.x.0.138):   Normal (Waiting)
                  Context02 Interface inside  (x.x.230.40):  Normal (Waiting)
                  Context02 Interface dmz     (x.x.203.1):   Normal
                  <removed details of other contexts>
                slot 1: empty
  Other host:   Secondary
                  Context01 Interface outside (x.x.0.133):  Normal (Waiting)
                  Context01 Interface inside  (x.x.230.44): Normal (Waiting)
                  Context01 Interface dmz     (x.x.8.2):    Normal
                  Context02 Interface outside (x.x.0.139):  Normal (Waiting)
                  Context02 Interface inside  (x.x.230.41): Normal (Waiting)
                  Context02 Interface dmz     (x.x.203.2):  Normal
                slot 1: empty
<removed details>
Context1/act#
There is more: if I ping the IP address of an interface on the standby context from the active context, this doesn't work for shared interfaces, but it does work for non-shared interface:
Context1/Context1/act# ping outside x.x.0.133
Sending 5, 100-byte ICMP Echos to x.x.0.133, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Context1/Context1/act# ping inside x.x.230.44
Sending 5, 100-byte ICMP Echos to x.x.230.44, timeout is 2 seconds:
Context1/Context1/act# ping dmz x.x.8.2
Sending 5, 100-byte ICMP Echos to x.x.8.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
Finally the Context complains about receiving spoofed traffic constantly. This is my real issue: all contexts generate these messages and it's flooding the Syslog server.
Context1/Context1/act# show logging
<removed details>
Aug 12 2011 13:04:48: %ASA-1-105009: (Primary_group_1) Testing on interface outside Passed
Aug 12 2011 13:04:48: %ASA-1-105009: (Primary_group_1) Testing on interface inside Passed
Aug 12 2011 13:04:48: %ASA-1-106021: Deny SCPS reverse path check from x.x.0.132 to x.x.0.133 on interface outside
Aug 12 2011 13:04:48: %ASA-1-106021: Deny SCPS reverse path check from x.x.230.43 to x.x.230.44 on interface inside
Aug 12 2011 13:04:52: %ASA-1-106021: Deny SCPS reverse path check from x.x.0.132 to x.x.0.133 on interface outside
Aug 12 2011 13:04:52: %ASA-1-106021: Deny SCPS reverse path check from x.x.230.43 to x.x.230.44 on interface inside
Disabling ReversePathFilter checking doesn't stop the messages. My guess is the ASA is blocking the "Hello" messages it needs to determine the monitor state of the interface. (Hence the waiting state....)
Any help is appreciated!
ASA version: 8.2(5)
Platform: ASA5520-K8
Kind regards,
Siebe
1 ACCEPTED SOLUTION
Highlighted
We ran into the same issue and apparently it is unpublished Cisco Internal bug. Go figure.
CSCtq28055
From TAC
You would not find this release on  the Cisco official website as it is an internal  release.
Need to upgrade to 8.2.(5.11).
Paul
10 REPLIES 10
Highlighted
Advocate
Can you share an output of " show run failover" from your firewall, for both the devices.
-Varun
Thanks, Varun Rao Security Team, Cisco TAC
Highlighted
Sure:
Context1/act# show run failover
failover
failover lan unit primary
failover lan interface failover-lan GigabitEthernet0/3
failover replication http
failover link failover-lan GigabitEthernet0/3
failover interface ip failover-lan 10.10.100.1 255.255.255.248 standby 10.10.100.2
failover group 1
  preempt 120
failover group 2
  preempt 120
Context1/act#
Context1/act# failover exec standby show run failover
failover
failover lan unit secondary
failover group 1
  preempt 120
failover group 2
  preempt 120
Context1/act#
Highlighted
Hi Siebe,
Its interesting that the ASA is seeing packets sent with a source of it's own IP address. Do you have mac-address auto enabled in the systems context? Try that and see if it helps.
Is this a new configuration or did you uprade to 8.2(5) and noticed it stopped working?
Prapanch
Highlighted
Hi Prapanch,
mac-address auto is enabled. I checked the MAC addresses and they are all unique.
I upgraded to 8.2(5) to see if it would solve the issue. Unfortunately I don't recall then this behavious started.
I'm guessing here, but the Cluster has had lots of "In-service Upgrades" and the cluster uptime is more than 4 year.
Context1/act# show version
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(5)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
smcfw05ztm up 11 days 10 hours
failover cluster up 4 years 114 days
Context1/act#
Could it be time for a clean boot?
Highlighted
Can you get captures from one of the contexts' shared interface? For example, from Context01:
cap capo interface outside match ip host x.x.0.132 host x.x.0.133
and then post the output of show cap capo
Prapanch
Highlighted
Here's what I've done:
First I used Wireshark to capture the hello's on the a non-shared interface. Look's like ASA uses IP protocol 105 to check the interface status of it's peer. I can see packets flowing in both directions. On a shared interface there were no packets with IP protocol 105. So my conclusion is that the hello's never leave the interface. To prove this a started a capture on the active en standby firewall:
Context1/Context1/act# show capture
capture drop type asp-drop all [Buffer Full - 524255 bytes]
Context1/Context1/act# show capture drop | in x.x.241.
2: 10:01:04.191167 x.x.241.13 > x.x.241.14:  ip-proto-105, length 48 Drop-reason: (rpf-violated) Reverse-path verify failed
4: 10:01:07.938260 x.x.241.13 > x.x.241.14:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
6: 10:01:07.943951 x.x.241.13 > x.x.241.14:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
8: 10:01:07.950344 x.x.241.13 > x.x.241.14:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
10: 10:01:07.956264 x.x.241.13 > x.x.241.14:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
Context1/Context1/stby# show capture
Context1/Context1/stby# show capture drop | in x.x.241.
2: 10:27:02.648388 x.x.241.14 > x.x.241.13:  ip-proto-105, length 48 Drop-reason: (rpf-violated) Reverse-path verify failed
4: 10:27:04.164755 x.x.241.14 > x.x.241.13:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
6: 10:27:04.170828 x.x.241.14 > x.x.241.13:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
8: 10:27:04.176290 x.x.241.14 > x.x.241.13:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
10: 10:27:04.177328 x.x.241.14 > x.x.241.13:  ip-proto-105, length 44 Drop-reason: (rpf-violated) Reverse-path verify failed
IP address x.x.241.13 and x.x.241.14 are the IP addresses on the inside interface for respectively the active and standby firewall.
So the ASA it dropping it's own packets. Since the ASA is complaining about RPF, I disabled RFP checking on all interfaces (no ip verify reverse-path interface inside). But the captured results were exactly the same!
Highlighted
Its interesting you do not see any packets leaving the ASA but you still see packets being dropped. Disabling RPF check is probably not helping here probably because the ASA sees the source IP address of the packet as it's own IP address.
I would suggest having this looked into by opening a TAC case if you have a valid support contract for this ASA as troubleshooting remotely this way will not really be feasible.
Do let us know if you manage to figure out what's going on.
Prapanch
Highlighted
CSCtq28055
From TAC
Paul
Highlighted
OK. Thanks for the heads up. This proves the issue is known and solved by Cisco.
Since it is not a serious issue, I will wait for Cisco to release either an interim release of 8.2(5) of maybe 8.2(6).
8.2(5) was released on the 23rd of May 2011, which is more than 3 month ago. So I guess it won't be long now....
Highlighted
Beginner
Cisco released interim release 8.2(5.13) on the 18th of September. After installing this version the issue was gone.
Interim Release Notes don't mention the BugID though.
Big thank you to Paul for providing the correct answer. Small thank you to everyone else that contributed.
Content for Community-Ad
