315
Highlighted
Beginner
Its Regarding ASA--its urgent pls help
Hi I have an issue, can anyone have a look and let me know how can i troubleshoot the issue. As per the packet-tracer output port is showing open but user is saying still he is unable to access port 21 and 22. can anyone tell me how can I check at switch end port is open or not.
Source IP add 172.18.56.31
Destination ip add 172.31.134.33
Source switch:
interface Vlan18
 description NOC-DR-Data Network
 ip address 172.18.56.1 255.255.255.128
 ip helper-address 166.77.80.252
 ip helper-address 172.20.116.10
 ip wccp 81 redirect in
 ip flow ingress
 hold-queue 2000 in
Source Swtich to destination trace
CORE1#traceroute 172.31.134.33 source 172.18.56.1
Tracing the route to 172.31.134.33
  1 172.20.245.38 0 msec 4 msec 0 msec
  2  *  *  *
  3  *
In firewall:-
asa# sh run route | i 172.
route outside 0.0.0.0 0.0.0.0 172.20.240.121 1
route inside 172.31.0.0 255.255.0.0 172.31.0.6 1
packet tracer output
asa# packet-tracer input outside tcp 172.18.56.31 2020 172.31.134.33 22
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   172.31.0.0      255.255.0.0     inside
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside-in in interface outside
access-list outside-in extended permit tcp object-group DIVA-DFM-SRC object-group DIVA-DFM-DST object-group DIVA-DFM-PORTS
object-group network DIVA-DFM-SRC
 network-object host 172.18.56.33
 network-object host 172.18.56.31
object-group network DIVA-DFM-DST
 network-object host 172.31.134.33
object-group service DIVA-DFM-PORTS tcp
 port-object eq ssh
 port-object eq ftp
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 6
Type: NAT
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 125702167, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
tnna-bc-asa#
2 REPLIES 2
Highlighted
You can telnet on port 21 and
You can telnet on port 21 and 22 to see if the service is open the destined device
telnet ip address 21
telnet ip address 22
Puneesh
Please rate helpful posts
Highlighted
Mentor
Hi, So the connection is
So the connection is coming from "outside" to "inside". The "packet-tracer" seems to suggest that the connection would go through the firewall. Seems there is no NAT performed so the connection should be visible to the remote device with its original IP address.
You could atleast do the following
  • Attempt the connection through the firewall and issue the command "show conn address <source or destination ip>" and check the output for the connection attempt that you are trying. Copy that output here to the forums so we can see what state the connection is in.
  • Check the remote device (Cisco switch?) if it has been configure with an "access-class" command and if it is then check the used ACL configuration and confirm that the source address is allowed in that ACL. If its not then naturally the remote management connection is not possible.
  • Check the path from the devices behind "outside" and "inside" interface of ASA that there is route for both the source and destination subnets. In the other directon the hosts are probably following the default route.
I am not really sure what command(s) can be used to check on a Cisco switch on what ports its listening on. Its not the same as on ASA atleast.
- Jouni
