340
Highlighted
NATing issue on CIsco ASA 5505 running 9.2
Hello Guys @balaji.bandi  @Rob Ingram  @Richard Burts  @Marvin Rhoads
Internal web server (WIIFI interface): 192.168.2.200
Public IP (Also WAN interface on ASA) : 99.250.21.105
I want to map port 443 of internal server to WAN IP of ASA and tried following commands.
object network HTTPS_IN
host 192.168.2.200
nat (WIFI,outside) static interface service tcp https https
Its not working and got following infio
5505# sh nat
Auto NAT Policies (Section 2)
1 (WIFI) to (outside) source static HTTPS_IN interface service tcp https https
translate_hits = 0, untranslate_hits = 40
2 (WIFI) to (outside) source dynamic obj_any interface
translate_hits = 6057, untranslate_hits = 198
5505# packet-tracer input outside tcp 8.8.8.8 https 192.168.2.200 https
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 192.168.2.0 255.255.255.0 WIFI
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: WIFI
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
5505# packet-tracer input outside tcp 8.8.8.8 https 99.250.21.105 https
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface WIFI
Untranslate 99.250.21.105/443 to 192.168.2.200/443
Phase: 2
Type: NAT
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
5505#
Please let me know if you need anything else?
2 ACCEPTED SOLUTIONS
Highlighted
VIP Mentor
it should be the same way as another post of yours :
The difference is you need to have an ACL Rule also to allow that traffic to Wifi, where is this Wifi device connected in the network.
you need a static route back to the wifi device from ASA,, you may have an outgoing default route.
the suggestion made based on the requirements, your topology, and full config we do not have visibility.
https://community.cisco.com/t5/network-security/cisco-asa-opening-port-80-443-but-limit-it-to-specific-public-ip/m-p/4148079#M1073700
BB
*** Rate All Helpful Responses ***
Highlighted
VIP Advisor
Hi @LovejitSingh1313
Is that the full configuration? I don't see the "access-group OUT2in in interface outside" command defined anywhere, therefore that ACL is not in use.
6 REPLIES 6
Highlighted
VIP Mentor
BB
Highlighted
Hello @balaji.bandi
Access-list was already there.
access-list OUT2in extended permit tcp any host 192.168.2.200 eq https
C 99.250.20.0 255.255.254.0 is directly connected, outside
C 192.168.2.0 255.255.255.0 is directly connected, WIFI
d* 0.0.0.0 0.0.0.0 [1/0] via 99.250.20.1, outside
Highlighted
Here is the config
5505(config)# sh run
: Saved
ASA Version 9.1(2)
hostname 5505
enable password pmUE.Vrp.6w6gHcX encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
shutdown
interface Ethernet0/1
switchport access vlan 5
interface Ethernet0/2
shutdown
interface Ethernet0/3
switchport access vlan 50
interface Ethernet0/4
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan5
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan50
nameif WIFI
security-level 100
ip address 192.168.2.1 255.255.255.0
boot system disk0:/asa912-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
object network obj_any
subnet 0.0.0.0 0.0.0.0
host 192.168.2.200
object network WEB-SERVER
host 192.168.2.200
object network WEB-SERVER_PUBLIC
host 99.250.21.105
object service TCP25
service tcp source eq smtp
access-list OUT2in extended permit tcp any host 192.168.2.200 eq smtp
access-list out2in1 extended permit tcp any host 192.168.2.200 eq https
pager lines 24
mtu WIFI 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any WIFI
icmp permit any outside
asdm image disk0:/asdm-7141-48.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (WIFI,outside) source static WEB-SERVER interface service TCP25 TCP25
nat (WIFI,outside) dynamic interface
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 WIFI
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 WIFI
ssh 192.168.2.0 255.255.255.0 WIFI
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 8.8.8.8
dhcpd lease 28800
dhcpd domain en
dhcpd address 192.168.2.100-192.168.2.130 WIFI
dhcpd enable WIFI
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username lsingh password SvQK35AQbGEfqr.k encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:e7cf15f33559d9acaee969c1dc2eeb85
: end
5505(config)#
Highlighted
VIP Advisor
Highlighted
@Rob Ingram  @balaji.bandi
OH **bleep** I cant beleive that I forget to apply access-list after defining it. Thanks alot guys.
Highlighted
VIP Mentor
Glad all working as expected, sure some time big config we miss some lines, but always to verify in our environment is good practice.
BB
Content for Community-Ad
