PIX 515 DHCP Problem
bretcollins
Visitor
We have a PIX 515 at a remote office. It is connected to a cable modem. We had a VPN up and running with no problems. The cable company did an upgrade and now the PIX will not get a DHCP address from the cable modem.
I have talked to them multiple times and they are telling me that it is a problem with our PIX. Before the upgrade we had a "sticky IP" so we always got the same IP address. They changed their entire IP scheme and I am thinking they have a reservation on their DHCP server that is no longer valid.
If I connect a broadband router to the cable modem and the PIX then the PIX will pick up an address from the router (192.168.x.x) but I need the PIX to have a public address. If I connect a PC to the cable modem the PC gets an public address, which is why they are telling me it is my PIX.
I ran debug dhcpc detail and this a sample from the output
DHCP get addr: existing ip lease str = 0xecec6c
DHCP: new ip lease str = 0xdd5194packet
DHCP client msg received, fip=10.8.x.x, fport=67
DHCP: Received a BOOTREP pkt Not for us..: xid: 0x1124
DHCP: QScan: Purging entry
DHCP: deleting entry dd4e54 0.0.0.0 from list
Temp IP addr: 0.0.0.0 for peer on Interface: unknown
Temp sub net mask: 0.0.0.0
DHCP Lease server: 0.0.0.0, state: 8 Purging
DHCP transaction id: 0x114A1
Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
No timer running
Retry count: 0 Client-ID:
DHCP: SDiscover attempt # 2 for entry:
Temp IP addr: 0.0.0.0 for peer on Interface: outside
DHCP Lease server: 0.0.0.0, state: 1 Selecting
DHCP transaction id: 0x20D04
Next timer fires after: 2 seconds
Retry count: 2 Client-ID: cisco-0013.mmmm.mmmm-outside
DHCP: SDiscover: sending 278 byte length DHCP packet
DHCP: SDiscover 278 bytes
DHCP Broadcast to 255.255.255.255 from 0.0.0.0
DHCP: SDiscover attempt # 3 for entry:
Retry count: 3 Client-ID: cisco-0013.mmmm.mmmm-outside
DHCP: QScan: Timed out Selecting state
DHCP: deleting entry eceacc 0.0.0.0 from list
DHCP transaction id: 0x15EF1
No timer running
I have changed their DHCP server's IP and the MAC address of the PIX. The PIX seems to be getting an DHCP offer but it says "not for us". Any ideas?
Patrick Laidlaw
Level 9
Level 9
This very same issues has happened to me for my test 515. I can not get it to lease a dhcp address from my cable modem provider. It leases an ip address from just about any other type of dhcp server just not off my cable modem.
CABLE MODEM---->Netgear switch/hub---->outisde DHCP 515--LAN
Patrick
