PIX 515 E FAILOVER Bundle issue- urgent help needed
hi ,
i hv a pix 515e wit UR bundle and another pix with FO bundle. I am able to
ping the interfaces of the pix with UR bundle. Bt the same configuartion is
nt working with FO bundle and am nt able to ping the interfaces. I am attaching
the text of both pix while it boots up and the configuartions. below is
working configuration of UR bundle which i tried on FO bundle which is nt working with it.Any post will be appreciated.
Regds
Binoy
OCSPIX# sh run
: Saved
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname OCSPIX
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
<--- More --->
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 172.16.1.1 255.255.255.0
ip address inside 192.168.1.5 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
pdm history enable
arp timeout 14400
global (outside) 1 172.16.1.2 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.x.x.x.16.1.3 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
<--- More --->
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.5.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxx
: end
5 Replies 5
haithamnofal
Level 3
Level 3
Hi Binoy,
I see from your configuration that failover is disabled, so you need to enable it by applying the following config on the primary unit but before you apply them make sure the failover cable is connected properly b/ the 2 units:
failover
failover ip address outside 172.16.1.2 255.255.255.0 (Change the address if it's used somewhere else)
192.168.1.6 255.255.255.0 (Change the address if it's used somewhere else)
wr mem
wr standby
run:show failover and look at the summary
Finally, it's better to go to the secondary and do "wr mem".
The configuration above will provide you with configuration replication and failover only, if you want stateful failover then you need to dedicate an interface between the 2 firewalls and do further configuration to define that interface and configure it.
Hope this helps,
Haitham
hi haitham,
thanks for your reply, my problm is not failover can you see the above configuration the same thing i coded in FO bundle pix its not pinging at all.
but the same code is working in UR bundle.i can ping using this configuration, need ur help in this.
Regds
Binoy
Hi Binoy,
You shouldn't apply the same config on the FO bundle unit.. All what you need to do is to connect the FO cable between the 2 units and apply the FO configurations as I suggested then turn on the FO unit which will syncronize the config with the primary.
Once the syncronization is complete, you should be able to ping the secondary unit on the addresses you assigned to it with your failover configuration commands.
HTH,
Haitham
hi haitham,
my issue is rt now its not connected as a FO unit,
as a stand alone unit it's not pinging with the above configuration.
just forget abt the failover, as a singler unit it's not working not pinging at all. pls verify the above configuration.
Regds
Binoy
It is a FailOver Unit not a Normal Unit. A failover license will not work as a standalone firewall, unless it is connected to a firewall that has a UR license that has failed, and the UR license firewall is configured to failover to the FO licensed firewall.
AFAIK the FO license will not allow this unit to act as a standalone.
Roger
