PPTP Traffic Not Passing
Muhammad.Eissa
i have issue in my network , as part of the work we need to connect to outside PPTP server but its always fail , works only if we connect directly to the gateway router.
back behind the ASA  the client cant connect ,  what is driving me crazy  is  when i do packet tracer with ASDM its show everything working fine ,
the below configuration is all i need to connect from client to outside server . also i have tried connect wireless and wired , but nothing
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect pptp
service-policy global_policy global
17 Replies 17
as per this photo . when you go to the access control, you will find your access control policy, then one of the options is adding
Identity Policy and SSL Policy, now in this if you have an ssl policy that mean your ssl inspection is active , and it's very important, by pressing on this policy and make it non that will remove the ssl inspection and the vpn will work.
maybe in your case the ssl inspection is mandatory so you  only will test and check if it works then  add it again and  open case with TAC for this issue.
i am waiting for the TAC respond for this issue , i will gave a summary later for all what we done.
I've found and disable SSL Policy but nothing has changed.
Still see GRE dropped ...
Muhammad.Eissa
problem is solved , and its issue  and will be solved in the next release
