04-22-2022 01:21 AM
Hello
we have two device ASA CISCO 5512 with HA ( primary and secondary ).
so i have problem :
FW1-Primary ( Active )
FW2-secondary ( Failed )
and it is we have an error message
one device is unknown state
you will find two pictures about error mesage :
Please , i need from expert security reply me and help me about this problem
Solved! Go to Solution.
04-22-2022 01:51 AM
if this is working one Failed or new setup :
Either case, check is the device online, by console, check the cables between devics. try to reload secondary and check.
04-25-2022 12:42 AM
@Dhikra Marghli check the INSIDE interface on the secondary ASA.
This host: Secondary - Failed
Active time: 0 (sec)
slot 0: ASA5512 hw/sw rev (3.0/9.9(2)88) status (Up Sys)
Interface diagnostic (0.0.0.0): Normal (Waiting)
Interface INSIDE (0.0.0.0): No Link (Waiting)
Check and replace the cable, check the interface configuration on the switch is correct. Attempt to ping the interface IP address.
04-22-2022 01:26 AM
@Dhikra Marghli has this ever worked?
Can you please run "show failover" and "show failover history" and provide the output.
04-25-2022 12:37 AM
04-25-2022 12:42 AM
04-22-2022 01:51 AM
04-25-2022 12:38 AM
