problem in network when configured Cisco FTD high-availability
Hacen.bani
hi team,
i have two ftd 2110on HA with two etherchannel ports to cisco core switch
in the switch i have an error message mac flapping, when i track the mac address !! is the mac of the ftd flapping between the two etherchannel.
i configured the ha active/standby but i show the two firewall active and one of them is disabled in FMC dashboard
please help in this issue
thanks in advance
Dennis Mink
so you have port channel A going to your FTD active and port channel B going to FTD passive and the mac address that lives on the inside interface of the FTD flaps between port channel A and B, in otherwords flaps between the two FTDs?
Please remember to rate useful posts, by clicking on the stars below.
thanks for reply
Yes,
after same times the two firewall gonna be active/active and the network goes down
in the FMC, i see one of the FTD disabled state
hi friend
any help with this issue, please !!!?
the two firewalls FTD 2110 after some time with HA config go to Active/active mode
the problem is dual active triggered
I upgraded the two firewalls to the recommended version but always the same problem.
thanks in advance
