problem on shuning th pix
mingchieh
my IDS is 4.0 with S37+IDM 4.0
my pix is 6.2(2)
When I configure shuning on my pix via telnet on IDM Web page
but it seems can not telnet the pix to do shuning (inside interface)
Why ?
(I have saw the post that pix 6.2(1) can not use telnet
Do I need to upgrade Pix to 6.3 , or upgrade my IDS ??)
7 Replies 7
stleary
Shunning with IDS 4.0 and pix 6.2(2) should work.
First, make sure you can telnet from the sensor
command line to the PIX, using the IPand login
information specified in your IDS configuration.
Next, make sure that you have configured IDS
blocking with both a logical device (contains the login
information) and a physical device (contains the IP,
protocol and a reference to the logical device).
Thanks for your help
but I can not enter telnet command on the IDS CLI
where is the telnet command ?
The telnet command is available on the sensor command line,
not the CLI. To get to the command line, set up a service
account and log in as a service account user. Then you can
telnet from a bash shell.
I have IDS 3.1 and PIX 6.2. Is telnet work with configuration. I have tested it and it seems does't work (statut:password sent... ) in IDS manager. I have tried ssh but the statut rest (statut:connecting). from the IDS ssh is working. But shunning doesn't work.
what can i do ?
Thank you.
In order for ssh to work, you must first connect to the pix using ssh from the sensor and accept the key. Then log in and get to enable mode,. If that works , it should work from the sensor.
Where can i find param of client ssh on IDS to connect to the PIX.
Thanks.
First log into the sensor as user netrangr. Then SSH into the PIX, using the
same username and password that the sensor uses. Note that the current
version of sensor software can only ssh to a PIX with a 3DES encryption
license. If your PIX uses DES encryption, you can obtain an engineering
build of nr.managed from CCO that will allow the sensor to connect.
