Problem with FWSM and SQL*Net
agustinmar
Hello, I have a FWSM and I have problem with Oracle server. The FWSM throws down the connections with Oracle server (port 1521).
I saw something message with this problem, but I haven't clear the solution.
Please, someone can help me.
Sorry for my bad english.
Thank you.
16 Replies 16
Hi All,
I'm experiencing similar issue.
I have an FWSM which originally run version 2.3(3). It is configured in multiple context mode. One of the contexts passes SQL*Net traffic (TCP port 1521).
Recently I upgraded the FWSM to 3.1(8). The end-user started to complain that their backup application (using SQL) took 12 hours to complete compared to 2 hours previously before the FWSM upgrade.
Comparing the "timeout" commands of both 2.3 and 3.1, I notice they are the same, as follows:
FWSM 2.3(3)
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 rpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
FWSM 3.1(8)
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
I have the following application inspection configs:
class-map class_sip_tcp
match port tcp eq sip
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect skinny
inspect smtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect xdmcp
class class_sip_tcp
inspect sip
The client is located at other parts of the network. The SQL server is located behind this FWSM context. Capturing packet trace on the client VLAN reveals many of the following messages:
[TCP Dup ACK...]
[TCP Retransmission...]
[TCP Out-Of-Order] [Continuation to #...]
[TCP ACKed lost segment]
Can anyone advise what's wrong with the FWSM? I can't find Release Notes of 3.1(8). Going through Release Notes of 3.1(9), I don't find any SQL-related issues.
Please help.
Thank you.
B.Rgds,
Lim TS
Hi.all
Trying remove "inspect sqlnet" on fwsm.
Maybe...problem solved.
