Problems logging into pix 501
justinspencer
I'm very new to cisco hardware and was wondering if anyone could help me with this (probably very simple question).
When connecting to my pix via the browser (https://192.168.1.1/startup.html), the browser never gets past the startup screen with the message that says 'loading, please wait'. This leads me to believe that the firewall is rejecting connections from my machine (which is using dhcp to get an ip from the pix).
To get around this, I've been trying to log into the cli using hyperterminal. I can connect and run some basic commands like 'show version', but can't login as a user with any permissions.
If the web interface has a default login of empty & empty, surely the cli should have the same?
Is anyone able to tell me what the default login is so that I can start confguring the pix via the cli?
Thanks in advance.
Justin Spencer.
Please see below for pix info:
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
pixfirewall up 12 mins 18 secs
Hardware: PIX-501, 16 MB RAM, CPU Am5x86 133 MHz
Flash E28F640J3 @ 0x3000000, 8MB
BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 0011.937e.0486, irq 9
1: ethernet1: address is 0011.937e.0487, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: 10
Throughput: Unlimited
IKE peers: 10
This PIX has a Restricted (R) license.
Serial Number: 808301473 (0x302db3a1)
Running Activation Key: 0xb53be54d 0x26da18f9 0xb2b78cef 0x8fe1abb6
Configuration last modified by enable_1 at 15:36:42.554 UTC Mon Nov 8 2004
pixfirewall>
long live java.
please mark this as solved, so others will not waste time.
thanks
Patrick Iseli
Level 7
Level 7
PDM Requirements !
1.) Verify that the browser you are using has the proper Java version.
a.) For Microsoft Internet Explorer, on the Windows system, select Start > Run and type wjview to determine the version (or type wjview at the DOS prompt). Sample output is shown below.
Microsoft (R) VM for Java, 5.0 Release 5.0.0.3802
The last four digits should be 3167 or greater to work with PDM.
2.)Enable the http service and add your hosts IP
http [netmask] [if_name]
http server enable
3.) Be sure that your browser permits popup for your PIX. Spcialy with Windows XP SP2.
4.) Your default login, try: with (no password). You have to create a password otherwise you cannot access it remote.
For ssh the default username will be "pix" with your enable password, but you need first to create a certificate.
Certificate creation:
hostname pix
domain-name yourdomain.com
ca generate rsa key 1024
ca save all
Password settings in this order:
enable
conf t
enable password
passwd
sincerely
Patrick
See this document:
Troubleshooting PIX Device Manager
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094ac1.shtml
sincerely
Patrick
Thank you Patrick. I shall try those recommendations.
Justin
Thanks for your help Patrick. The problem was the lack of the java vm on my workstation.
It's all sorted now.
long live java.
thanks
