Problems with Zone based Firewall and mtr (mytraceroute)
Stefan Giera
We are using ZFW on an ASR1001 and have experienced a problem: when I try to use mtr (mytraceroute, see
http://en.wikipedia.org/wiki/MTR_%28software%29), I am getting packetloss on all hops between the source and the destination. e.g.:
<code>
        Packets               Pings
Host        Loss%   Snt   Last   Avg  Best  Wrst StDev
1. Stuttgart-I28-1.belwue.de        100.0     8    0.0   0.0   0.0   0.0   0.0
2. Stuttgart-AL30-1-gi0-0-0-3.belwue.net        100.0     7    0.0   0.0   0.0   0.0   0.0
3. Karlsruhe-RZ-1-10GE-0-1-0-1.belwue.net        100.0     7    0.0   0.0   0.0   0.0   0.0
4. Karlsruhe1-10GE-4-0-0.belwue.net        100.0     7    0.0   0.0   0.0   0.0   0.0
5. Mannheim1-10GE-3-0-0.belwue.net        100.0     7    0.0   0.0   0.0   0.0   0.0
6. Frankfurt-DECIX-1-10GE-0-0-0-0.belwue.net        100.0     7    0.0   0.0   0.0   0.0   0.0
7. de-cix20.net.google.com        100.0     7    0.0   0.0   0.0   0.0   0.0
8. 72.14.238.230        100.0     7    0.0   0.0   0.0   0.0   0.0
9. 72.14.239.62        100.0     7    0.0   0.0   0.0   0.0   0.0
10. 209.85.242.187        100.0     7    0.0   0.0   0.0   0.0   0.0
11. ???
12. ???
13. ???
14. bk-in-f94.1e100.net        0.0%     7   20.0  20.6  20.0  21.2   0.4
</code>
So it seems that the Firewall on my asr1001 is throwing away all packets with ttl-exceeded coming back from hops in between, they have another destination address.
At the moment I am inspecting all kind of traffic from my network outgoing:
ip access-list extended 101
permit ip any any
class-map type inspect match-all cmap1
match access-group name 101
policy-map type inspect pmap1
class type inspect cmap1
inspect
etc... (zones, zone-pair in-out with policies applied)
So I tried to let pass all icmp-traffic from the outside to my network:
class-map type inspect match-all cmap_icmp
match protocol icmp
policy-map type inspect pmap2
class type inspect cmap_icmp
pass
etc... (zones, zone-pair out-in with policies applied)
So this has no effect, but I tested and I could figure out, that when I pass all icmp-traffic from my network to the outside, THEN mtr does work.
BUT then normal ping does not work anymore, because it will not be inspected any more.
But I want to have a secure Firewall with inspecting echo-replys and working mtr anyway.
Has anyone the same problem or can even solve this issue?
Thanks in advance,
Stefan
9 Replies 9
andrew.prince
Level 10
Level 10
In the URL you provided I noticed
"MTR also has a UDP mode (invoked with "-u" on the command line or pressing the "u" key in the curses interface) that sends UDP packets, each with an increasing destination port, toward the destination host. When the UDP mode is used, MTR relies on ICMP port unreachable packets (type 3, code 3) when the destination is reached"
have you tried this?
Yes I tried this and it worked fine, but our border-routers are filtering udp-packets, so this isn't favorable for our NOC...
Have you tried to "inspect" ICMP outbound and "pass" ICMP time-exceeded inbound.
Hi Andrew, thanks for Your answer...
So I have now:
class-map type inspect match-any cmap_icmp
match access-group name icmp_types
ip access-list extended icmp_types
permit icmp any any ttl-exceeded
PMAP IN--> OUT
(don't be confused, my "vlanxxx_pmap_in" is the pmap FROM my network TO the outside...)
policy-map type inspect vlan664_pmap_in
class type inspect vlan664_cmap_in   (this is an extended ACL "permit ip x.x.x.x any")
  inspect
class type inspect ipsec_cmap_in (this is because I have problems with VPN when inspected, another problem...)
  pass log
class class-default
  drop log
PMAP OUT-->IN
policy-map type inspect vlan664_pmap_out
class type inspect cmap_icmp (here comes the "ttl-exceeded"-ACL)
  pass log
class type inspect vlan664_cmap_out (some open ports for some clients)
  inspect
class type inspect ipsec_cmap_out (same problem with VPN when inspected)
  pass log
class class-default
  drop log
But unfortunately, the same problem occurs. Curiously, the first two packets seem to go "through" the firewall, but with 3rd packet the packetloss comes up:
                                                Packets               Pings
1. Stuttgart-I28-1.belwue.de                 50.0%     3    0.3   0.3   0.3   0.3   0.0
2. Stuttgart-AL30-1-gi0-0-0-3.belwue.net     50.0%     3    0.9   0.9   0.9   0.9   0.0
3. Karlsruhe-RZ-1-10GE-0-1-0-1.belwue.net     0.0%     2    2.7   2.7   2.7   2.7   0.0
4. Karlsruhe1-10GE-4-0-0.belwue.net           0.0%     2    1.5   1.5   1.5   1.5   0.0
5. Mannheim1-10GE-3-0-0.belwue.net            0.0%     2    2.5   2.5   2.5   2.5   0.0
6. Frankfurt-DECIX-1-10GE-0-0-0-0.belwue.net  0.0%     2    4.1   4.1   4.1   4.1   0.0
7. de-cix20.net.google.com                    0.0%     2    5.0   5.0   5.0   5.0   0.0
8. 72.14.238.44                               0.0%     2   39.2  39.2  39.2  39.2   0.0
9. 72.14.236.68                               0.0%     2    5.4   5.4   5.4   5.4   0.0
10. 209.85.254.118                             0.0%     2    5.4   5.4   5.4   5.4   0.0
11. ???
12. google-public-dns-a.google.com             0.0%     2    5.5   5.3   5.2   5.5   0.2
                                                 Packets               Pings
1. Stuttgart-I28-1.belwue.de                  66.7%     4    0.3   0.3   0.3   0.3   0.0
2. Stuttgart-AL30-1-gi0-0-0-3.belwue.net      66.7%     4    0.8   0.8   0.8   0.8   0.0
3. Karlsruhe-RZ-1-10GE-0-1-0-1.belwue.net     66.7%     4    2.1   2.1   2.1   2.1   0.0
4. Karlsruhe1-10GE-4-0-0.belwue.net           66.7%     4    1.5   1.5   1.5   1.5   0.0
5. Mannheim1-10GE-3-0-0.belwue.net            66.7%     4    2.6   2.6   2.6   2.6   0.0
6. Frankfurt-DECIX-1-10GE-0-0-0-0.belwue.net  66.7%     4    4.2   4.2   4.2   4.2   0.0
7. de-cix20.net.google.com                    66.7%     4    5.3   5.3   5.3   5.3   0.0
8. 72.14.238.44                               66.7%     4   70.3  70.3  70.3  70.3   0.0
9. 72.14.239.60                               66.7%     4    5.8   5.8   5.8   5.8   0.0
10. 209.85.254.116                             66.7%     4    5.8   5.8   5.8   5.8   0.0
11. ???
12. google-public-dns-a.google.com              0.0%     4    6.3   5.7   5.2   6.3   0.5
In the sessions on the routers, I see only this entry:
         Session 206F66C (129.143.6.89:8)=>(8.8.8.8:0) icmp SIS_OPEN
Any other suggestions?
What are the results with normal trace route? I use "wintrace" as an example
Normal traceroute looks good:
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 40 byte packets
1  Stuttgart-I28-1.belwue.de (129.143.6.65)  0 ms  0 ms  0 ms
2  Stuttgart-AL30-1-gi0-0-0-3.belwue.net (129.143.56.225)  1 ms  1 ms  1 ms
3  Karlsruhe-RZ-1-10GE-0-1-0-1.belwue.net (129.143.57.46)  2 ms  2 ms  2 ms
4  Karlsruhe1-10GE-4-0-0.belwue.net (129.143.57.50)  2 ms  1 ms  1 ms
5  Mannheim1-10GE-3-0-0.belwue.net (129.143.1.174)  3 ms  3 ms  3 ms
6  Frankfurt-DECIX-1-10GE-0-0-0-0.belwue.net (129.143.1.22)  12 ms  12 ms  9 ms
7  de-cix20.net.google.com (80.81.193.108)  5 ms  5 ms  5 ms
8  72.14.238.230 (72.14.238.230)  5 ms (TOS=128!) 72.14.238.44 (72.14.238.44)  59 ms 72.14.238.46 (72.14.238.46)  5 ms
9  72.14.239.62 (72.14.239.62) [MPLS: Label 684488 Exp 4]  28 ms 72.14.236.68 (72.14.236.68) [MPLS: Label 474319 Exp 4]  5 ms 72.14.239.62 (72.14.239.62) [MPLS: Label 669096 Exp 4]  6 ms
10  209.85.254.114 (209.85.254.114)  5 ms 209.85.254.118 (209.85.254.118)  6 ms 209.85.254.112 (209.85.254.112)  5 ms
11  * * *
12  google-public-dns-a.google.com (8.8.8.8)  5 ms  5 ms  5 ms
But what can I do now?
Normal traceroute is good, but mtr is throwing away all reply ttl-exceeded packets after the 2nd reply-packet.
I also tried to set high the icmp idle and ageout-timers with a parameter-map, but this does not help either :-(
Well you could just use normal traceroute - it does the same thing.  You have other options to look at, like wintrace or pingplotter - they all do the same thing.
JMTPW.
