Reset management interface IP address through CLI on Firepower 1010
EvanC75
Can someone tell me what the command is through CLI to reset the management IP address on a Firepower 1010?  The Cisco documentation for this is wrong.  It does not provide any examples and no matter what I try, it says syntax error.
This is what I am trying and it does not work.
connect ftd
configure network management-data-interface ipv4 manual 10.0.1.1 255.255.255.0
Regards.
@EvanC75 use configure network ipv4 manual  <ip address> <netmask> <gateway>
You can confirm that worked using the command show network
Thank you.  I had a hard time finding the show network command.
What confused me from the Cisco documentation is it told me to do it like this which apparently is wrong:
configure network management-data-interface ipv4 manual 10.0.1.1 255.255.255.0 default-gw 10.0.1.254
Also I tried it without the default gateway.
So basically I didn't need the "management-data-interface" part of it.
Regards.
How do I change the management interface on a 3130 to be on the "inside" interface but before that, how do I set nameif to inside on a different interface (want to use 10G instead of 1G)?
