11-07-2013 12:40 AM - edited 03-11-2019 08:01 PM
I'm trying to set up Cicso asa csc-ssm-10 modules for failover, and see the following messasge, when setup is complete and after system failover has been enabled:
InterScan for CSC SSM could not establish a connection. The software, hardware, and patch version on the peer devices must match. Please reconcile the mismatch that was detected and try again.
What could be the issue?
11-07-2013 12:44 AM
Sadly I have no knowledge of the actual modules that the ASA use since we dont use them in our environments.
But the main thing about any ASA Failover pair is that they should be identical in every way down to the software levels.
The above error message to me atleast clearly suggest that there is some missmatch between the devices. That would be the first thing to check.
- Jouni
11-07-2013 02:34 AM
Yes, Jouni you are absolutely right, both devices should be Identical from hardware, software and licensing perspectives here are the output from show module 1 details command from both devices
__________________________________________________
ciscoasa# show module 1 details
Getting details from the Service Module, please wait...
ASA 5500 Series Content Security Services Module-10
Model: ASA-SSM-CSC-10
Hardware version: 1.0
Serial Number: JAF1125001C
Firmware version: 1.0(11)2
Software version: CSC SSM 6.6.1125.0
MAC Address Range: 001b.54f7.8d00 to 001b.54f7.8d00
App. name: CSC SSM
App. Status: Up
App. Status Desc: CSC SSM scan services are available
App. version: 6.6.1125.0
Data plane Status: Up
Status: Up
HTTP Service: Up
HTTPS Service: Up
Mail Service: Up
FTP Service: Up
Activated: Yes
Mgmt IP addr: x.x.x.11
Mgmt web port: xxxxx
Peer IP addr: x.x.x.1
Model: ASA-SSM-CSC-10-K9
Serial Number: JAD164401TU
Firmware version: 1.0(11)5
MAC Address Range: 30f7.0dbc.ca96 to 30f7.0dbc.ca96
App. name: CSC SSM
App. Status: Up
Status: Up
HTTP Service: Up
HTTPS Service: Up
Mail Service: Up
FTP Service: Up
Activated: Yes
Mgmt IP addr: x.x.x.22
Peer IP addr: x.x.x.2
11-07-2013 03:55 AM
Does this error come once both devices are configured?
Here is something you might wan to try. If it doesn't jump to the correct section when you open the link, look under important notes section:
http://www.cisco.com/en/US/docs/security/csc/csc66/release/notes/cscrn66.html#wp344834
