shared public IP with same tcp port (round robin/load balance)
yann.boulet
Hi all,
I want to know if I can do that with my ASA5515-X, I have two servers that can do the same thing, there are SSO servers, What I want to do is to publish the 2 servers on Internet with the same public IP address and on TCP 443.
Is it supported ? will it works like load balancing per sessions ?
or do I need to add an HLB between ASA and my SSO servers ?
5 Replies 5
sokakkar
Hi Yann,
You can configure the ASA to allow traffic to your SSO server from outside on two public IP's. Users can hit either of the IP to reach the inside server. Now, load balancing would be achieved based on source devices sending request to public IP's. If source machine son internet use one public IP more to access the server, ASA can't do anything to load balance in such scenario. Here is how you can accomplish this:
Assuming SSO server on inside is 192.168.16.110 and two public IP's are 192.168.17.110 and 192.168.17.111
object network SSO_1
host 192.168.17.110
object network SSO_2
host 192.168.17.111
object network SSO
host 192.168.16.110
object service https
service tcp source eq https
nat (inside,outside) source static SSO SSO_1 service https https
nat (inside,outside) source static SSO SSO_2 service https https
Hostname(config)# sh xl
2 in use, 6 most used
Flags: D - DNS, i - dynamic, r - portmap, s - static, I - identity, T - twice
TCP PAT from inside:192.168.16.110 443-443 to outside:192.168.17.110 443-443
    flags sr idle 0:00:06 timeout 0:00:00
TCP PAT from inside:192.168.16.110 443-443 to outside:192.168.17.111 443-443
    flags sr idle 0:00:08 timeout 0:00:00
Verification:
Hostname(config)#    packet-tracer input outside tcp 4.4.4.4 discard 192.168.17.110 443
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Additional Information:
NAT divert to egress interface inside
Untranslate 192.168.17.110/443 to 192.168.16.110/443
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside in interface outside
access-list outside extended permit ip any any
Phase: 3
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3670, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
Hostname(config)#    packet-tracer input outside tcp 4.4.4.4 discard 192.168.17.111 443
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Untranslate 192.168.17.111/443 to 192.168.16.110/443
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3671, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
Sourav
thanks sourav,
but in your scenario I can only use one of my 2 internal SSO servers ?
thx
Yann
Hi Yann,
My bad! I misunderstood your question. I provided config for one server on inside and allow connections to it from internet using two mapped IP's. Now, in your case we will need the ASA to load balance the incoming requests on a public IP to two internal servers on TCP 443. Which I am afraid to tell but can't be accomplished on ASA.
ASA will need to have two mapped IP's in this case. However, you can put some load balancing device in b/w for which we can have a one to one static or port forward on TCP 443 and that can load balance the request received on its IP to two inside servers.
Sourav
thanks sourav for your time.
it means that I need HLB..
yann
Yes, that is correct.
Sourav
Please rate the helpful posts, ask question if you need any further help.
