Static NAT and same IP address for two interfaces
jeff6strings
Level 4
Level 4
We have a Cisco ASA 5520 and in order to conserve public IP addresses and configuration (possibly) can we use the same public IP address for a static NAT with two different interfaces? Here is an example of what I'm refering too where 10.10.10.10 would be the same public IP address.
static (inside,Outside) 10.10.10.10  access-list inside_nat_static_1
static (production,Outside) 10.10.10.10  access-list production_nat_static_1
Thanks for any help.
Jeff
varrao
Level 11
Level 11
Hi Jeff,
Unfortunately this cannot be done, on the ASA packet classification is done on the basis of mac-address, destination nat and route, and here you are confusing the firewall, to which interface does the ip belong to. I haven't ever tried to do it, but it should cause you issues.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
varrao
Level 11
Level 11
Hi Jeff,
Varun Rao
Security Team,
Cisco TAC
Varun Rao
Varun,
Thank you for the reply and we will use an IP address just for this project.
jeff
