11-04-2011 12:26 AM - edited 03-11-2019 02:45 PM
I have configured in Asa 5520 as below
object-group network MOBILE_IN
access-list MOBILE extended permit ip object-group MOBILE_IN any
nat (inside) 5 access-list MOBILE
so whenever i tried to open youtube it open but when i click on a video it's not played..
11-04-2011 10:16 PM
Hey,
I dont think the NAT has anything to do with this. At the end of the log you put, there is a reason for the teardown. We need the following info to give you a little bit help here:
1-What is the rest of that log
2-Do you have any kind of web filter?
3-What happens if you NAT the same traffic to the interface IP?
4-Do you have any kind of police (QoS)?
5-Does the video appears but it doesnt load?
6-Do you have a CSC module?
7-Have you changed either MTU or MSS of the firewall?
8-Do you see errors on the interfaces?
9-Does it happens to all Devices?
This will give us a liitle bit more info in order to find out the issue.
Mike.
11-05-2011 12:40 AM
1 I got below two logs when i hit youtube.com
6 Nov 05 2011 12:09:26 302016 203.18.137.1 161 172.16.5.98 3953 Teardown UDP connection 12187127 for outside:203.18.137.1/161 to inside:172.16.5.98/3953 duration 0:02:01 bytes 194
6 Nov 05 2011 12:09:32 302016 203.18.137.1 161 172.16.5.98 3954 Teardown UDP connection 12187336 for outside:203.18.137.1/161 to inside:172.16.5.98/3954 duration 0:02:01 bytes 191
2 . NO i don,t have any webfilter
3 . hi i donot try to nat it to interface ip ..
4.no i donot have any Qos.
5. yes youtube.com open but very slow after opening i am able to see video but when i click on video it does not play.
6. yes i have cisco IPS.
7 no i donot changed MTU.
8. no error on interface.
9. Do you mean on all pc,s that are in mobile group ?
I have issue only in youtube website other video sites like msnvideo open perfectly..
Prashant
11-06-2011 02:04 PM
Is it possible that you can try this it bypassing the Cisco IPS and let us know.
I have faced this issue at a customer site once really can't remember what was the solution! Try the IPS first please.
