VPN traffic flow problem
JohanKardell
Level 2
Level 2
I'm having some trouble with getting cisco vpn traffic to flow from a remote site that's using NAT to my home Cisco VPN connection, the connection is established, but I can't do anything with my VPN connection, ping, and reach my home network is not working, the only thing I can reach is Internet, since I'm using Split Tunneling.
I have tried to connect from my iPhone to my home VPN, and that's no problem, I can then reach all resources on my home network.
I have also tried to set up a new VPN connection, on my home ASA, without Split Tunneling, and can then only reach my public ip at my home ASA, that's, only ping it.
The remote site is using a cisco firewall as well, but the problem is that I can't provide or get into that firewall, there should not however be any restrictions for outgoing VPN traffic.
I'm sorry for not being able to provide all information, my question is more If there's is anything in my config that could cause this behavior?
I do however understand that there's most certainly something on the remote network that's stopping me, and I do understand that there's very little information I'm providing, just curious, and wondering If someone can take a quick glance at my config... See if there's anything that's wrong.
I'm not however asking you to solve my problem, this is more a question see If I have configured anything strange / wrong.
Thanks so much!
Here's my config:
: Saved
ASA Version 8.0(3)
hostname UsersASA
domain-name default.domain.invalid
enable password XXXXXXXXXXXXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 172.16.30.1 255.255.255.0
interface Vlan10
nameif outside
security-level 0
ip address 95.95.95.7 255.255.255.128
interface Ethernet0/0
switchport access vlan 10
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd XXXXXXXXXX encrypted
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list nonat extended permit ip 172.16.30.0 255.255.255.0 172.16.30.32 255.255.255.248
access-list MSS_EXCEEDED_ACL extended permit tcp any any
access-list VPN-SPLIT-TUNNEL remark VPN SPLIT TUNNEL
access-list VPN-SPLIT-TUNNEL standard permit 172.16.30.0 255.255.255.0
tcp-map MSS-MAP
  exceed-mss allow
pager lines 24
logging enable
logging timestamp
logging buffer-size 8192
logging console notifications
logging buffered notifications
logging asdm notifications
mtu inside 1500
mtu outside 1500
ip local pool VPN 172.16.30.33-172.16.30.38 mask 255.255.255.248
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-625-53.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 172.16.30.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 95.95.95.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 172.16.30.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh 172.16.30.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 172.16.30.10-172.16.30.30 inside
dhcpd dns 95.95.95.52 95.95.95.67 interface inside
dhcpd lease 432000 interface inside
dhcpd domain HOME interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
group-policy VPNHOME internal
group-policy VPNHOME attributes
dns-server value 95.95.95.52 95.95.95.67
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN-SPLIT-TUNNEL
split-dns value 95.95.95.52 95.95.95.67
msie-proxy method no-proxy
username admin password XXXXXXXX encrypted privilege 15
username User password XXXXXXXX encrypted privilege 0
username User attributes
vpn-group-policy VPNHOME
tunnel-group VPNHOME type remote-access
tunnel-group VPNHOME general-attributes
address-pool VPN
default-group-policy VPNHOME
tunnel-group VPNHOME ipsec-attributes
pre-shared-key *
class-map MSS_EXCEEDED_MAP
match access-list MSS_EXCEEDED_ACL
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect tftp
  inspect icmp error
  inspect pptp
  inspect ipsec-pass-thru
  inspect icmp
class MSS_EXCEEDED_MAP
  set connection advanced-options MSS-MAP
service-policy global_policy global
privilege cmd level 3 mode exec command perfmon
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command packet-tracer
privilege show level 5 mode exec command import
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command asp
privilege show level 3 mode exec command cpu
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command vlan
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command ipv6
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command eigrp
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command vpnclient
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command wccp
privilege show level 3 mode exec command webvpn
privilege show level 3 mode exec command module
privilege show level 3 mode exec command uauth
privilege show level 3 mode exec command compression
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
prompt hostname context
Cryptochecksum:f450c4621b8c6a366d3067c05313b959
: end
Parminder Sian
Level 5
Level 5
Hi Johan,
To begin with, please assign a vpn pool with different range, say for example 10.10.10.0 255.255.255.0. Overlapping pools with internal network or in same range is not recommended even if you use different subnet mask.
Secondly enable "crypto isakmp nat-traversal", right now you have "no crypto isakmp nat-traversal".
Hope this helps,
Sian
5 Replies 5
Parminder Sian
Level 5
Level 5
Hi Johan,
Hope this helps,
Sian
Thank you so much! I'll try this as soon as possible tomorrow
It kind of works :)!
I can now reach the resources on my lan from the remote site, for example I have a disk at 172.16.30.2 that I can reach when connected to the vpn, one problem though, I can't reach rescoures that's on my asa's dhcp scoop.... from the vpn client..
I have applied 10.10.10.0/24 to my vpn client pool..
this is now my current config
: Saved
ASA Version 8.0(3)
hostname KardesASA
enable password XXXXXXXXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan10
nameif outside
security-level 0
ftp mode passive
protocol-object udp
protocol-object tcp
access-list nonat extended permit ip 172.16.30.0 255.255.255.0 10.10.10.0 255.255.255.0
tcp-map MSS-MAP
  exceed-mss allow
pager lines 24
logging enable
logging timestamp
logging console debugging
mtu inside 1500
mtu outside 1500
ip local pool VPN 10.10.10.1-10.10.10.30 mask 255.255.255.0
arp timeout 14400
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd domain kardellskillby interface inside
dhcpd enable inside
default-domain value kardellskillbyvpn
username admin password XXXXXXXXXXX encrypted privilege 15
username Karde password XXXXXXXXXXX encrypted privilege 0
username Karde attributes
address-pool VPN
pre-shared-key *
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp error
  inspect pptp
  inspect icmp
Cryptochecksum:aaa1f198bf3fbf223719e7920273dc2e
: end
THANKS!!!!!!!!!!
Hi Johan,
What is the default gateway on the the pc's or server those pick the ip from asa's dhcp scope? It should internal ip address of ASA i.e 172.16.30.1.
if it is and still dosent work, try adding a static route on these machines i.e to reach vpn pool go to asa inside interface.
Sian
My bad :/! I restarted the ASA, now it works !!
Thanks for all the help!
Much appreciated!
