I haven't been able to get into the lab to test this yet but was wondering if someone here had a quick answer.
The situation is a customer needs to use an ASA device to set up two L2L vpns.  The problem is that at each remote end they have an overlapping address that the ASA side needs to connect to.  It's not possible for the remote sides to either NAT this address or change it.  I know I can set up outside to inside NAT in this situation, but I've never tried it with two overlapping addresses on the remote end.  Or if someone else has a better solution, please let me know.
If you need more clarification, please let me know.
Thanks....
