Edgar c Francis
BGP Weight Attribute
A Cisco router can use the BGP weight, in that router to influence that one router’s choice of outbound route. To do so, when a router receives a BGP update, that router can set the weight either selectively, per route, using route map or for all routes learned competing routes, choosing the route with the bigger weight.
Weight is cisco proprietary attribute, weight tells how to exit the autonomous system. Path with the highest weight is more desirable range is 0 through 65,535, by default 0 for learned routes, 32,768 for locally injected routes. weight is partial attribute, set on inbound route update.
lets see the configuration:-
Topology:-
GOAL:
  • configure the topology as per the diagram.
  • configure the basic iBGP and EBGP peering using directly connected interfaces.
  • advertise all the interfaces as per the topology
  • configure the next-hop address should be the next router address
  • configure router 4 to prefer exit path via router1 to reach all the networks.
R1#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        10.1.1.1        YES NVRAM  up                    up
Serial3/0                   1.1.1.1         YES NVRAM  up                    up
Serial3/3                  4.1.1.2         YES NVRAM  up                    up
Loopback0              11.0.0.1        YES NVRAM  up                    up
Loopback1              11.0.1.1        YES NVRAM  up                    up
Loopback2              11.0.2.1        YES NVRAM  up                    up
Loopback3              11.0.3.1        YES NVRAM  up                    up
R2#show ip interface brief
FastEthernet0/0        20.1.1.1        YES NVRAM  up                    up
Serial3/0                    1.1.1.2         YES NVRAM  up                    up
Serial3/1                    2.1.1.1         YES NVRAM  up                    up
Loopback0              12.0.0.1        YES NVRAM  up                    up
Loopback1              12.0.1.1        YES NVRAM  up                    up
Loopback2              12.0.2.1        YES NVRAM  up                    up
Loopback3              12.0.3.1        YES NVRAM  up                    up
R3#show ip interface brief
FastEthernet0/0        30.1.1.1        YES NVRAM  up                    up
Serial3/1                    2.1.1.2         YES NVRAM  up                    up
Serial3/2                    3.1.1.1         YES NVRAM  up                    up
Loopback0              13.0.0.1        YES NVRAM  up                    up
Loopback1              13.0.1.1        YES NVRAM  up                    up
Loopback2              13.0.2.1        YES NVRAM  up                    up
Loopback3              13.0.3.1        YES NVRAM  up                    up
R4#show ip interface brief
FastEthernet0/0        40.1.1.1        YES NVRAM  up                    up
Serial3/2                    3.1.1.2         YES NVRAM  up                    up
Serial3/3                    4.1.1.1         YES NVRAM  up                    up
Loopback0              14.0.0.1        YES NVRAM  up                    up
Loopback1              14.0.1.1        YES NVRAM  up                    up
Loopback2              14.0.2.1        YES NVRAM  up                    up
Loopback3              14.0.3.1        YES NVRAM  up                    up
R1(config)#router bgp 65111
R1(config-router)#neighbor 1.1.1.2 remote-as 65111
R1(config-router)#neighbor 4.1.1.1 remote-as 65444
R1(config-router)#neighbor 1.1.1.2 next-hop-self
R1(config-router)#network 10.0.0.0
R1(config-router)#network 1.0.0.0
R1(config-router)#network 4.0.0.0
R1(config-router)#network 11.0.0.0 mask 255.255.255.0
R1(config-router)#no auto-summary
R1(config-router)#no synchronization
R2(config)#router bgp 65111
R2(config-router)#neighbor 1.1.1.1 remote-as 65111
R2(config-router)#neighbor 2.1.1.2 remote-as 65333
R2(config-router)#neighbor 1.1.1.1 next-hop-self
R2(config-router)#network 20.0.0.0
R2(config-router)#network 2.0.0.0
R2(config-router)#network 1.0.0.0
R2(config-router)#network 12.0.0.0 mask 255.255.255.0
R2(config-router)#no auto-summary
R2(config-router)#no synchronization
R3(config)#router bgp 65333
R3(config-router)#neighbor 2.1.1.1 remote-as 65111
R3(config-router)#neighbor 3.1.1.2  remote-as 65444
R3(config-router)#network 30.0.0.0
R3(config-router)#network 3.0.0.0
R3(config-router)#network 2.0.0.0
R3(config-router)#network 13.0.0.0 mask 255.255.255.0
R3(config-router)#no synchronization
R3(config-router)#no auto-summary
R4(config)#router bgp 65444
R4(config-router)#neighbor 3.1.1.1 remote-as 65333
R4(config-router)#neighbor 4.1.1.2 remote-as 65111
R4(config-router)#network 40.0.0.0
R4(config-router)#network 4.0.0.0
R4(config-router)#network 14.0.0.0 mask 255.255.255.0
R4(config-router)#network 3.0.0.0
R4(config-router)#no synchronization
R4(config-router)#no auto-summary
R1#show ip bgp summary
BGP router identifier 11.0.3.1, local AS number 65111
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
1.1.1.2         4        65111      14      13       14    0    0 00:06:21        7
4.1.1.1         4        65444      14       9       14    0    0 00:02:07        7
R2#show ip bgp summary
BGP router identifier 12.0.3.1, local AS number 65111
1.1.1.1         4        65111      13      14       14    0    0 00:06:56        7
2.1.1.2         4        65333      11      12       14    0    0 00:04:29        6
R3#show ip bgp summary
BGP router identifier 13.0.3.1, local AS number 65333
2.1.1.1         4        65111      13      12       14    0    0 00:05:27        9
3.1.1.2         4        65444      11      14       14    0    0 00:03:59        9
R4#show ip bgp summary
BGP router identifier 14.0.3.1, local AS number 65444
3.1.1.1         4        65333      14      12       21    0    0 00:04:25       10
4.1.1.2         4        65111      11      16       21    0    0 00:04:05        9
R4#sh ip bgp
BGP table version is 21, local router ID is 14.0.3.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
 *>  1.0.0.0          4.1.1.2                  0             0       65111 i
 *                          3.1.1.1                  0         65333 65111 i
 *   2.0.0.0          4.1.1.2                                0 65111 i
 *>                   3.1.1.1                  0             0 65333 i
 *>  3.0.0.0          0.0.0.0                  0         32768 i
 *                    3.1.1.1                  0             0 65333 i
 *>  4.0.0.0          0.0.0.0                  0         32768 i
 *                    4.1.1.2                  0             0 65111 i
 *>  10.0.0.0         4.1.1.2                  0             0 65111 i
 *>  11.0.0.0/24      4.1.1.2                  0             0 65111 i
 *>  12.0.0.0/24      4.1.1.2                                0 65111 i
 *   13.0.0.0/24      4.1.1.2                                0 65111 65333 i
 *>  14.0.0.0/24      0.0.0.0                  0         32768 i
 *>  20.0.0.0         4.1.1.2                                0 65111 i
 *   30.0.0.0         4.1.1.2                                0 65111 65333 i
 *>  40.0.0.0         0.0.0.0                  0         32768 i
R4#traceroute 30.1.1.1
Tracing the route to 30.1.1.1
VRF info: (vrf in name/id, vrf out name/id)
  1 3.1.1.1 168 msec 60 msec 24 msec
To reach the 30.1.1.1 router 4 by default using 3.1.1.1 interface because it has less numbers of AS.
but we want to router 4 go via 4.1.1.1 interface to reach all the networks.
R4(config-router)#neighbor 4.1.1.2 weight 20000
R4(config-router)#end
R4#clear ip bgp * soft
  1 4.1.1.2 8 msec 56 msec 4 msec
  2 1.1.1.2 [AS 65111] 52 msec 40 msec 36 msec
  3 2.1.1.2 [AS 65111] 52 msec 40 msec 64 msec
R4#show ip bgp 30.1.1.1
BGP routing table entry for 30.0.0.0/8, version 22
Paths: (2 available, best #1, table default)
  Advertised to update-groups:
  Refresh Epoch 2
  65111 65333
    4.1.1.2 from 4.1.1.2 (11.0.3.1)
      Origin IGP, localpref 100, weight 20000, valid, external, best
      rx pathid: 0, tx pathid: 0x0
  Refresh Epoch 3
  65333
    3.1.1.1 from 3.1.1.1 (13.0.3.1)
      Origin IGP, metric 0, localpref 100, valid, external
R4#show ip bgp
R4#show ip bgp
BGP table version is 29, local router ID is 14.0.3.1
 *>  1.0.0.0          4.1.1.2                  0         20000 65111 i
 *>  2.0.0.0          4.1.1.2                            20000 65111 i
 *                    4.1.1.2                  0         20000 65111 i
 *>  10.0.0.0         4.1.1.2                  0         20000 65111 i
 *>  11.0.0.0/24      4.1.1.2                  0         20000 65111 i
 *>  12.0.0.0/24      4.1.1.2                            20000 65111 i
 *>  13.0.0.0/24      4.1.1.2                            20000 65111 65333 i
 *>  20.0.0.0         4.1.1.2                            20000 65111 i
 *>  30.0.0.0         4.1.1.2                            20000 65111 65333 i
