Aninda Chatterjee
Good morning!
Now that I am over the E3 2012 excitement (I wish I could rant about that here, but alas..), I finally found time to sit down and write some of what I am studying. Of course it's pretty basic stuff and I know that. It's just that I want to start from the absolute basics and build on it slowly, day by day.
So today, we're going to look at how we can configure a nice little frame-relay cloud for ourselves. I just got my 2522 router a while back and I bought this specifically to convert it into my frame relay cloud. This router is pretty handy; it has 10 serial ports, 1 AUI port (which can be converted into an Ethernet port by using a 10BaseT MAU transceiver). Very cool!
Here's the topology that we'll be working with:
The 'cloud' is my 2522 router and that's where we'll be sitting on for the entirety of this post. The connections are pretty straightfoward. I have a serial connection from the end routers to the 2522 router. R1's S0/0/0 goes to Serial1 of the 2522 router, R6's S0/0 goes to Serial6 and so on.
The first step is to enable frame relay switching.This is done by the global configuration command 'frame-relay switching'.
The frame-relay switch must act as the DCE end of the link. We need to specify this with the frame-relay intf-type dce interface command and then provide the clock rate as well using the clock rate <clock rate> interface command.
Next is to specify how the DLCIs are connected to each other. This is done using the frame-relay route route <inbound DLCI> interface <outbound interface> <outbound DLCI>.  This is telling the switch that the other end of 'X' DLCI is 'Y' DLCI.  It essentially binds the outgoing interface and the two DLCIs together into a  virtual circuit.
Also, don't forget to set the encapsulation of the interface to frame-relay using the encapsulation frame-relay interface command. That should be the first step without which you  won't see any of the frame-relay commands under the interface:
FRSwitch(config)#interface Serial 1
FRSwitch(config-if)#frame-relay?
% Unrecognized command
So, at the end of the day, our four serial interfaces on the 2522 should look like this:
FRSwitch#show running-config interface serial 1
Building configuration...
Current configuration : 246 bytes
interface Serial1
no ip address
clockrate 56000
frame-relay route 103 interface Serial3 301
frame-relay route 106 interface Serial6 601
frame-relay route 107 interface Serial7 701
end
FRSwitch#show running-config interface serial 6
Current configuration : 156 bytes
interface Serial6
no ip address
clockrate 56000
frame-relay route 601 interface Serial1 106
end
FRSwitch#show running-config interface serial 7
interface Serial7
no ip address
clockrate 56000
frame-relay route 701 interface Serial1 107
end
FRSwitch#show running-config interface serial 3
interface Serial3
no ip address
clockrate 56000
frame-relay route 301 interface Serial1 103
end
That's pretty much it. We have our 'cloud' set up. All we need to do now is to configure the end routers and blow some things up Again, I know this is pretty basic but we'll be using the above configuration to dive deeper into how frame-relay works along with some general frame-relay troubleshooting in my next post (let's hope we don't have to wait till E3 2013 for that ).
I hope this was informative.
9 Comments
Somasundaram Jayaraman
Good one Aninda!, Just to add few more things, we can have point to multipoint configurations as well, using the frame-relay ip statements.
Some useful show commands,
show frame-relay route,
show frame-relay pvc <>
show frame-relay lmi
And LMI packets would be of this format,
Cheers,
Somu
Aninda Chatterjee
Thanks Somu I just posted another one with more detailed information and the show commands you listed here:
https://supportforums.cisco.com/community/netpro/network-infrastructure/routing/blog/2012/08/20/frame-relay-part-i
I hadn't actually seen a LMI packet till now. I'll probably take a packet capture sometime and look at it in more detail.
Nice work!!
Alessio
CSCO12165174
Nice one.
Currently doing CCNP Switch and want to move back into routing soon with a framerelay setup
v.haciyev
thank you/
it is nice work
Daniel Vieceli
Thanks!
Adam Sorenson
I have a question concerning this.  In my current topology (which is a voice/collaboration lab)  I am using my PSTN router for Frame-Relay switching.  My full-mesh WAN and all the PVCs are working.  My main question is about whether or not I can allow my PSTN router to participate in the WAN.
I used the "connect" command for my call routing logic which defines how the PVC connections pass through the PSTN router.  Is there a way that this can be configured to define an endpoint on the PSTN router?
blue phoenix
Hi Adam,
I think the PSTN router can participate in L3 since the interfaces that need to be in frame-relay mode has to have a hard-coded configuration of encapsulation frame-relay.  My 2 cents only...
Martin L
Interesting.... thanks for sharing!
