10-07-2020 11:05 AM
Hi guys,
As the subject line states, can this be accomplished via the rv345 GUI?
To be clear, I want to assign a client machine on my LAN to use a specific WAN port (1 or 2).
Your thoughts
10-07-2020 11:33 AM
As per my understanding, you want to send LAN device XY to WAN1, and ZZ to WAN 2 port s this correct- then PBR is the question to send using WAN 1 or WAN 2 port.
if the above statement is correct, then your subject is wrong. "How to assign LAN IP to WAN Port rv345 Dual-WAN Router"
10-07-2020 12:42 PM
Hey BB,
Thanks for this. Wasn't sure what the right subject line would be.
Can you point me to some documentation regarding PBR specific to this router?
10-08-2020 03:40 AM
check do you have option available under
Networking ---Routing--Policybased routing ?
