Zurattos
Hello ,
I really need your help , how can I configure a management vlan for the switch while using GRE tunnel between two routers ?
Best Regards
4 Comments
kapydan88
Level 4
Level 4
Hello.
Do you want to configure management ip address for remote router or for any switch? Because i think, that term "management vlan" is valid for switch only.
Zurattos
I have as usual vlan 1 but I don't know how to configure management vlan instead of vlan 1 to log in with telnet and ssh
Zurattos
This picture represents my topology I want to mange the switch from my PC MT is Mikrotik routers  GRE R1 and R1 cisco switches and SWI is a switch when I use show ip interface brief vlan 100 management vlan protocol is down !
kapydan88
Level 4
Level 4
conf t
vlan 100
name management
int vlan 100
ip add 1.2.3.4 255.255.255.0 (this is mgmt ip for your switch)
try to fins any interface vlan on your switch
sh ip int br
